Nope. An engine oiling system is hydraulic - if the internal guts have the proper clearances oil pressure builds and flows - and the oil filter inlet holes are designed to pass a LOT more oil than necessary for an engine in good condition. Unles the engine is severely worn, oil pressure is determined by rpm, oil temperature (~190 - 215 is ideal), oil pressure relief spring, and the total of all internal lubricated bearings condition. Pressure and flow is lubrication (and cooling) - simple pressure is not.
Calculate the area of the inlet holes compared to the area of the center (outlet) threaded hole. Gonna be pretty close, regardless.
Oil pressure relief and bypass spring/plunger ....................... For most GM, about 55 - 60 psi.
