1 - 13 of 13 Posts
2002 Deville base
02' DeVille, Crimson, 1300w Sub, Tinted
Need more loud out of my 2002 deville already did a resonator delete still have the cat and the stock mufflers I’m looking at flowmaster 44s I may get rid of the cat if it’s not loud enough after that even. But as far as I know the flowmasters are a 2.25 inlet and outlet. will these clamp to the 2inch exhaust after the y-pipe or will I need adapters?
Was looking at these ones: Flowmaster® 942446 - Super 44 Series Delta Flow™ Aluminized Steel Oval Black Exhaust Muffler (2.25" Offset ID, 2.25" Center OD, 13" Length)
2008 Escalade ESV 2WD 6.2
Deleting resonators is a pointless exercise. They do not impede exhaust flow and only supress drone. You don't sound very mature, seeking loudness on a Cadillac rather than a performance increase, and I will offer nothing further. Why don't you check with Flowmaster for compatability?
before you get too goofy hacking stuff off the car - go yo YouTube -
there are several videos of Northstar powered Deville - Seville - and Eldorado with various loud mufflers -
THAT is a FEDERAL offense - punishable by FLOGGING -
you can NOT crush a 2.25 pipe over 2" pipe and expect a good seal -
a real muffler shop would probably make a short adapter
to fit OVER the existing pipes and INTO the muffler -
2002 Deville base
Wow why even bother replying? Just cause it’s a Cadillac doesn’t mean it has to be quiet.
Okay makes sense and am
I better off taking it to a muffler shop to do any exhaust work? Cant really find any adapters that size
YES - as I said - a real muffler shop will be able to make the correct adapters
so the job is done right the first time
Done correctly, here's what it should look like. And the muffler hanger rods need to be welded in the correct positions/angles or the entire system will rattle against the body and center pipe heat shield.
Land vehicle Vehicle Car Bumper Automotive exterior
Looks good, you have a video of it running?
this is NOT a couple of flowmaster mufflers hacked into place -
Sub's STS has the full cat-back CORSA stainless steel system - around $1500 just for the parts -
and it delivers the PRETTIEST sound ever emitted from a Northstar powered car -
2002 Deville base
Discussion Starter · #12 ·
Just guessing, but if the OP wants the sound of Flowmaster 44's, I suspect he'd not be happy with the CORSA.
Corsa system sounds better than the "truck" tone of the flow masters obviously, flow masters are just cheaper don't wanna put a lot of money into this car when the corsa system is worth he value of the car
The CORSA is plenty loud and will literally wake the dead when you get on it. Rumbly in town and no - no - drone on the open road. The pic was used to illustrate what an aftermarket install should look like, not to push CORSA. Unless the DIY modifier is a true Michelangelo of welders/benders then exhaust work is best sent to a GOOD shop or the results may well be less than satisfactory.
I paid just over $1000, shipped, for that system back in 2006. Even at the current $1500 (special order now) price it's still far, far less expensive than the STS is "worth". It's not productive to know the price of everything and the value of nothing.
1 - 13 of 13 Posts
