1 - 8 of 8 Posts
I have ´01 STS. I just received a DIC-message "Change brake pads".
Do they usually wear the same amount on both ends or does the front pads wear faster? I just want to know which end I should check first!
I have 57000 miles in ODO.
· Cadillac Technician
none
Probably closer to 80%
Check the fronts first.
As noted below, however, be sure to check the rears also... you never know.
2004 Escalade, 07 Road King, 08 Challenger SRT8
Fronts, absolutely.
HOWEVER.... I would at least inspect the rears, make sure everything is okay....
Years ago on my 92 Eldorado, I did the fronts, everything was fine... until a rear claiper stuck on me, and covered my wheel with nasty scorching hot brake dust, that I couldn't remove... ended up finding another wheel at a junkyard.... so at least make sure the rears look good, maybe take them off, grease everything up with that silicone grease stuff, and make sure they are moving properly, pads are good, etc.
As the other's correctly said, the fronts do the majority of the stopping...thus, a rear brake problem is often overlooked, because it feels like it's stopping okay.
The fronts definitely wear faster than the rear if everything is working properly, but not knowing when the last time the fronts or rears were changed, you would be best to check them both.
1 - 8 of 8 Posts
