1997 Professional Chassis Raised Roof Presidential Limousine
Have a 2008 DTS and the "service parking assist" message is displayed. I hooked up my clone Tech2 but can't see what section it would be in. Chassis or Body? Couldn't find anything in either. BTW which body is this, K or Y? Looked in both.
Should be a k. You have to get into the tpms system as the the parking assist comes off of that module as well. At least on our 06 thats where it is.
The TPMS is part of the RCDLR. Look under (object alarm module)
TECH 2 From the main screen F:0 Diagnostics, Select Year, Select Vehicle Type ( passenger car), Select System, (Diagnostic Circuit Check), Select (Class 2 DTC Check) The Tech 2 will poll all the Modules for DTC’s. It will build a list of all the modules it finds and tell you if it has any DTC’s with that module.
PCM 0 no codes
BCM 4 4 codes
EBTCM 1 1 code
