1 - 16 of 16 Posts
i just bought a 93 FWB and was doin a tune up .
I replaced the thermostat in the normal place on top of the block under #29(see pic) but when i was looking through the coolant diagram and its in the location of #16 (see pic)
what do you guys recommend?
this is my first L05 motor so im little confused.
thanks in advance
csbuckn,
that diagram is the exact layout in my caddy.
ill remove the bottom t-stat and try it out.
thanks
84 Coupe w/500
Interesting, I thought the 93 RWD Caddy had a TBI 350, same motor from 90-93. Guess not. Looks like you're gonna be buying a lot of coolant since the radiator and block will probably drain out. I've never seen that bracket(18) before. "My bad".
84 Coupe w/500
^Yea, thats what I was saying, the TBI 350 that was in my 90 didnt have that extra piece down at the bottom(18)...nor the extra piece going to the radiator(3). Musta had a couple changes in 93. I would think two therms would be pointless if they didnt open at the same time anyway.
Discussion Starter · #7 ·
i think out the info.
i went to caddy today to get diagram.
One of the mechanics said they probly put a junction and the T-Stat there was to get hotter coolant to the heather core faster.... for caddy owners!
on my junction there is 2 lower rad hoses plus a heater core return line.
2014 ELR
That is super weird. I have never looked at a 93 D body TBI, and I have NEVER seen that #18 setup. Certainly not like that on any other L05 I have seen (or owned).
Can we get a picture?
84 Coupe w/500
Is that a smog delete? The only thing I see on rockauto is an option for HD cooling in the belts section.
84 Coupe w/500
That is a nice website, found a bunch of recalls for the cars I have. They had the 90 Brougham all wrong in the diagram section but the TSB listings are very helpful in the info section.
1 - 16 of 16 Posts
