1 - 11 of 11 Posts
Discussion Starter · #4 ·
Thanks for the link LUVMY04V! I have FE4's, should I get FG2's, if I was going to go with a set of GC's? I will not be using my V at the track, it's more for ride hieght adjustment, since I have 20's, and to get a little stiffer ride. Any input appreciated
ZIP
If you want to keep FE4s, get 400lb springs. Get 500-600 with FG2s.
ZIP
So would FE4's with the GC's be the best setup for purely street use? I wanted to maintain at least some type of Caddy ride when i'm cruisin'.
The GC kit comes with adjustable perches and springs. The springs and your shocks will dictate how your V rides. The adjusters just play with your ride height.
G
Their street setup is 500/550. Their other one comes with 600/650. You can call them and get any combination you can think of. I had the 500/550 with FE4's and the ride was nearly identical to stock.
Banned
05 CTS-V
there are about 3 other threads that have the same talk in them... check them out... but to help you out i bought qa1 shocks and GC 600 fronts and 650 rears. ride is much more stiff car is planted better and ride is superb!
1 - 11 of 11 Posts
