This is and was unbelievably helpful, saved $275 and it works. So my Cadillac CTS had a key fob happy owner and no new key fobs could be programmed in my car. Only came with one Master Key Fob so I needed to clear the 4 existing keys in my car memory. Called three Atlanta dealers (Classic, Hennessy and Heritage) and every one of them said it requires the Dealer to reset and reprogram the DIC system … minimum one hour repair rate of $275 but probably more. So this guy on Social Media reads my thread and says nah… He’s a former ASCE Mechanic for GM…. and holy crap, it works.
If you have a Cadillac or GM with a Keyless Remote System and Memory Security and to program another fob… takes about 30 minutes and you MUST DO IT 3 TIMES …!
Step 1: First we need to gather up all your fobs and make sure they all have good batteries in them.
Step 2: We will need to find out if there are more fobs programmed to your car than you have on hand - put one fob into the cup holder and then take your physical key and place it into the driver side door lock. turn the key to the unlock position 5 times in 5 seconds. You will hear a ding and the DIC will display "Ready To Learn Electronic Key #X" x represents a number between 1 and 4. If you currently have two fobs and it says it is ready to learn key #3, then just simply press your ignition knob in and go about your day because your fine and there are no other key fobs that are programmed to your car outside of what you have. If you were like me, mine said key #4 and i currently only had one fob, so that meant that there were two fobs that were programmed to my car that i did not have access to. If this applies to you, continue to step 3.
Step 3: Push the ignition knob in to exit out of program mode.
Step 4: Take your fob out of the cup holder and place all active fobs at least 5 or more feet away from the car so that your car can not sense them.
Step 5: Take your physical key and stick it into the driver side door lock and turn it to the unlock position 5 times in 5 seconds, you will hear a ding.
Step 6: The DIC will display "Press Start Control To Learn Keys".
Step 7: Press your ignition control knob, the display will read "Learn Delay Active Wait 10 Min" it will then flash the message "No Electronic Key Detected" and then will go back to saying "Learn Delay Active Wait 10 Min" when it comes up the second time, the countdown begins and it will count down by the minute.
Step 8: Repeat steps 6 and 7 two more times.
Step 9: When the countdown ends for the 3rd time, you will hear a beep and the DIC will say "Ready To Learn Electronic Key #1" At this point, all previous and current key fobs have been deleted and you are starting fresh.
Step 10: Take one of your key fobs and place it into the key fob pocket in the center arm rest with the top facing down and the buttons facing forward. You will hear a beep and the DIC will display "Ready To Learn Electronic Key #2".
Step 11: Do step 10 for all remaining key fobs, up to 4 of them Step 12: Press the ignition knob to complete programming.
Step 13: Press the unlock button on each fob to confirm programming.
This definitely gave me peace of mind knowing that only the fobs that i had on hand would work on the car. hope this helps someone out. ❤👍💪👏🙏
