99 STS, White Diamond
I greatly neglected my PS system and when I checked the fluid about five weeks ago it was virtually black with a hint of burned smell.
Over three days I flushed nearly 1 gallon (6 oz at a time) with at least 5-6 full turns of the wheel between drain/fill and often a short drive. The fluid finally drained to look like new.
Since then, I've drained the reservoir and refilled three times in about two weeks noticing that the fluid was a bit darker.
Today I drained the reservoir (it had been about three weeks) and the fluid is dark amber--nothing like at the beginning but hard to describe as power steering fluid...
Should I continue to flush in hopes that the system was just utterly filthy?
Or give up flushing, order a pump and rack and wait for it to fail?
Only problem with the steering system was a very rare, momentary loss of power steering when pulling into a parking space. I have not noticed this since I began flushing, but again it was a very rare occurrence.
2010 DTS
I'd say a failure (probably the rack) is eminent, but you probably have some time if you want to wait.
1996 Eldorado
The fluid will darken normally. Some of that being crud tailings in the nooks & crannies in the system. Some of these systems have a P/S filter that is mounted on the outside right front sub frame rail. I think it was discontinued on the later models.
The main thing is to have fresh fluid and hope the pump & rack continue to be trouble free.
I'll continue to flush for a while.
I'm more a cabinetmaker, plumber and electrician than automotive mechanic and sadly lack any tools to raise a vehicle beyond simple ramps. Perhaps attempt a DIY rack replacement even if I suffer the embarrasment of having it moved on a flatbed to the garage. Not so much about money, but I'm truly enjoying learning how to repair modern cars...
