1 - 2 of 2 Posts
2001 DHS
Is it better to check the oil stick in the morning while the engine is cold or when it's warmer? Or any difference at all?
Re: When to check the oil stick
Any time the engine has been off for more than 5 minutes, level ground. Engine oil level differences, hot or cold, are almost unmeasurable.
Here's your proper oil level ...............Read P.3 of the sticky post in Engines; Northstar - "Northstar piston ring cleaning". There is a statement there from GM/Cadillac on proper oil fill procedure.
<=== ADD XXXXXXXXXX <-- OPERATING RANGE ==============oo==========================O
http://www.cadillacforums.com/forums/northstar-engines-system-technical-discussion/198220-northstar-ring-cleaning-procedure-proper-oil.html
1 - 2 of 2 Posts
