I had a 2000 Monte Carlo SS, and I bought aftermarket 17" wheels for it. I no longer own the car.
Can I put those wheels on my 93 Deville?
I know the bolt pattern (5x115) is the same. Is there anything else I should be concerned about?
is the SS fwd? if it is it might work, i heard some where, dunno if its true, that all fwd GM wheels would work. I dont think its true, but if you have the wheels still, try it and see.
White Diamond 2001 STS
Yeah, I think it'd work. Both vehicles are FWD, so you should have close to the correct wheel dimensions. I'd take a wheel off your Deville and do some loose measurement comparisons between that one and one from your Monte Carlo. If they're close, bolt one on the Deville and check it out. I'm guessing it'll be a perfect fit.
2005 CTS-V, 1994 Infiniti Q45
I would assume they would fit also......
