'87 SDV
Thinking about swapping out the steel wheel/wire hubcaps on an '87 DeVille for some alloys, preferably Cadillac wheels. Thought it might be good to ask here for suggestions.
What years of Cadillac factory alloys will swap in directly? Has anyone done a change that looked particularly good?
Thanks!
Thanks!
They can be changed, im not sure what years though.
Stoney has 00-05 DTS wheels on his 94 Deville...... looks great
2007 EXT Supercharged
87's will be way different from 02's, but may work.
Ive seen 89 and 91's (which interchange with 87') and they have put 94-95 on those too.
You will need new tires for sure, the newer ones wont be 14" wheels.
01 frontier , 89 Shelby CSX vnt
stock wheels with stock size tires will work just fine ....offsets and everything are the same ....
like in my case .....i went from my stock 15 inch wheels and stock size tire to the stock size wheel and tire from a 01 DTS , kept the speedo the same and everything ....for some reason cadillac never changed offset or ovrall diameter of the tire and wheel combo over the years (as far as i can tell)
to be safe use tirerack.com , select your car , then select a wheel that measure the same inch diamter and width as what you want , itll give the right tire size after that
Unicycle
any '85+ FWD Cadillac wheels should interchange without issue.
I have '98-mid '01 Seville SLS wheels on my 1993 Coupe DeVille, our chassis are very similar too, yuo should have no problem.
car origanally had 15" steelies with wure wheel hub caps and white walls.
