Ahh that makes sense. So they are slightly taller. Are they still the run flat type tires?
Ahh that makes sense. So they are slightly taller. Are they still the run flat type tires?Sorry I needed a correction. The tires are 255 35 20. Didn't want to mislead anyone who wanted a similar look thanks
Ended up getting my PPF installer to add a blacked out PPF cutout over the R and it came out great.#1 shouldn't have been a surprise, as wheel center caps are not a standardized size. I've played with cars from a variety of brands over the past few decades - domestic, Japanese, and Euro - and have never heard of aftermarket wheels that could use the OEM center caps, with the exception of wheels that were specifically made to be knock-offs of factory wheels.
Measure the diameter of the new center caps, go on Ebay, and find yourself some suitable adhesive Cadillac emblems. That'll take care of #1 and #3 at the same time! If you don't find something you like there, reach out to someone like Rebadge Designs - he can do all sorts of custom stuff.
No. I went with non run flats for slightly better ride.Ahh that makes sense. So they are slightly taller. Are they still the run flat type tires?
Hey, came across your post on google. I was also looking at getting the br14 wheels. I was curious did you get the 9.5? And what width tire, 255?Got the tires on, stock rims and winters weighed around 62-63 lbs give or take. So pumped lol.
Did you read any of the thread before posting? If you do, you'll find your answers.Looking at a set of wheels for my ct5v that are 20"x9" and curious if anyone knows if they would fit, and if so what offset I would need?
I did read above and saw most wheel sets at 8.5 or 9.5 so wasn't sure if Goin a 9" width would change anything on the offset?Did you read any of the thread before posting? If you do, you'll find your answers.
Of course, wheel width and offset aren't the only things that matter for fitment on a car with opposed piston calipers. Make sure whoever you're buying from guarantees fitment over the big Brembo calipers.
If you're going with 9s, I would imagine an offset that is mid-point between the offsets for the 8.5 and 9.5 widths should work. In the earlier posts, it was reported that OE was 29 on 8.5s and that a poster mounted 9.5s with a 35 offset.I did read above and saw most wheel sets at 8.5 or 9.5 so wasn't sure if Goin a 9" width would change anything on the offset?
Mostly worried about interference and rubbingIf you're going with 9s, I would imagine an offset that is mid-point between the offsets for the 8.5 and 9.5 widths should work. In the earlier posts, it was reported that OE was 29 on 8.5s and that a poster mounted 9.5s with a 35 offset.
Are you worried about the look or interference with the suspension/brakes?
Fair. I would be as well. That being said, if 9.5s work with a 35 offset, you shouldn't have a problem with 9s with a reasonably similar offset. What diameter are you looking at?Mostly worried about interference and rubbing
This is a 20x10 / 20x11 build.Widths and offsets?
Just looking to see what you used in your specific applicationThis is a 20x10 / 20x11 build.
Wheel fitments are specific to each application. Whenever the time is right for yours we will walk through the process and dial it in for your performance or aesthetic needs
