I'm in Manotick, so probably not that far from you. Out here, 19s would be fine in the winter - the worst potholes are in the city itself.
I'm in Manotick, so probably not that far from you. Out here, 19s would be fine in the winter - the worst potholes are in the city itself.Yeah, I was in a situation where I had to toss winter onto the stock rims because I got the car right off the truck (I didn't order the car, just took someone's order since they backed out) Worked out though because I wanted to get some black wheels and they couldn't get a OEM set in black. I'm only like a hour+ south of Ottawa. Had no issues with the heavy snowfalls this past winter, but 18s would be great for a bit of more meat for the potholes.
I'm excited to get my summers on with the black rims and see how it looks, I'll post some pics up when I get them on, tires should be in next week, then just gotta get them balanced and mounted.
Thanks for the feedback.I'm in Quebec and my stock 19's on winters survived the crappiest roads in Canada without any issues.
245-40R19 have massive sidewalls for what they are honestly.
(Better than the 235-40R18 that were on my previous CT4-V, and even those, survived the same roads without any issues.)
I never downsize cars in the winter personally as the OEM wheels always end up being the "winter wheels".
What 18" take off's are you referring to? I'm pretty sure the V only came with 19" and 20" depending on the package. Not to say an 18" wouldn't fit, of course. If an 18" from a different trim CT5 fit that'd be awesome.I recently ordered a CT5V but don't have a build date. Regardless, I don't expect my car before the end of the summer and am kind of torn here - my brain tells me to get 18s for the winter and keep the stock 19s for summer duty as I don't think a 40 aspect ratio on the stock 19s would do all that well on many of the roads up here (my city - Ottawa - runs its annual pothole festival from February to May every year). But I am tempted to go with nice aftermarket 19s for the summer and keep the stock 19s for the winter.
Did others in snowy areas consider 18s for the winter?
A non-V such as a premium luxury. They're out there.What 18" take off's are you referring to? I'm pretty sure the V only came with 19" and 20" depending on the package. Not to say an 18" wouldn't fit, of course. If an 18" from a different trim CT5 fit that'd be awesome.
Yeah that's an important point. I don't know what kind of caliper clearance is required on the V. I might just stick with the 19s as the winter wheels and look for different 19s for the summer.There's definitely some on Canadawheels also. My biggest concern would be fitment over the rotors and brembos. When I clean my wheels, the calipers are pretty damn close to the wheel's barrel that it's hard to clean between the rotor and barrel. If your ordering from somewhere make sure you get guaranteed fitment/good return policy incase their is an issue is probably the best way to go about it, hopefully you get it figured out way before winter so you aren't forced into doing anything you don't want.
I don't even have any confirmation that GM has accepted the order. I have plenty of time...Lol if they gave you a vin already you can just call your dealership parts department and confirm 18s will fit with your vin. With all the websites showing 5x115 Bolt pattern and only odd ones showing 5x120, I called my dealerships parts Dept to get them to get m exact wheel specs based on my vin.
Good luck, and hope you enjoy your car when you get it.
Looks really good 👍Got the tires on, stock rims and winters weighed around 62-63 lbs give or take. So pumped lol.
Looks great !Got the tires on, stock rims and winters weighed around 62-63 lbs give or take. So pumped lol.
20's still have the same overall height though !Thanks! Wish they made our cars have less wheel gap, lol maybe they left it that big so the cars with 20s look mint ahah
Looks purty.Got the tires on, stock rims and winters weighed around 62-63 lbs give or take. So pumped lol.
Yeah. I think I am going to take delivery of my car and drive it stock for the first winter before I decide if the winters are going to be 18s or 19s.Well, in reality, 255-35R20 is 0.3" taller than 245-40R19, but on the car, that's just a 0.15" difference in "wheel gap" and 0.15" more in 4x4 stance.
So pretty negligible. But you do have 0.7" less sidewall, so on the roads, they would be more prone to damage on our beautiful Canadian roads !
I'd say base your choice on what you want to do with the stock wheels since the 19's have plenty of sidewall already.Looks purty.
