1 - 16 of 16 Posts
What is the widest we can run on the front and rears of our car without having ANY issues or modifications? Im am considering getting same sizes in front and back to make tire rotation/tire life better.
May try to get another set of our stockers in 19" for front, but seems pretty wide.
· Banned
STS, XLR, STS V-Series, CTS V-Series, XTS....
9 inch in the front is already pretty wide. You "MIGHT" be able to squeeze a 9.5" front, but I dont know if the factory rears offset will work...
Good luck.
Dr. Design
D3 Cadillac
· Banned
295's in the rear!! However that is on an aftermarket wheel. If you are asking how wide of a tire you can run on a factory rim, that would be a 285 tire. This would be the minimum allowable width to secure the tire on the rim.
No rubbing, no modifications, etc...
Thank you,
Dr. Design
D3 Cadillac
How about the rear tires?
· Banned
10.5 inch wide wheel in the rear on a 295 tire. Anything more than that you will have to trim or you might run interference with the fenders...
Thank you,
Dr. Design
D3 Cadillac
Im not doing a good job of typing what im thinking. I am asking what is the widest width of wheel in the rear you can run, and with that the widest tire.
2010 CTS-V, 2009 Escalade ESV
Dan
Which tire brand and full spec (295-??) are you using on the rear? Since you said no problems, you must be OK even with the lower springs.
06 STS-V, 08 STS-V, 14 Raptor, 12 Camaro SS, 08 FJ
How do you like the way those tires fit on your ride? I am looking at getting some Nitto Invos and they come in those sizes
I like them. They throw the speedo off 3 MPH. So you think you are going 50 when you are really going 47. much cheaper as well to go that size as well. I really wanted the Nitto but they didn't have them in stock when I really needed tires. Next time I am going to try them. So far I love the T-R's
Cadillac 06 STS-V, 86&87 GN, 69 Riv
Cool, I will have to check out the Toyos too. How long do those last about? In spirited driving of course :D
I heard good things with the Nittos Invos, I will let you know how they actually are when I put them on.
1 - 16 of 16 Posts
