1 - 17 of 17 Posts
If you looking to do wheels or suspension on your escalade just give me a holler. I've done it all and sell the replica wheels and thru testing when these trucks first hit the streets in late 2006 I narrowed it down to the best kits for the 07 - 14 lowering.
On my own escalade started with 22s then 24s then 26s. I went from a 2/3 to now a 3/5 and full swaybars and control arm upgrades plus more. Feel free to text/call me 24/7 at 415 519 2432 or email [email protected]
Current height which is my custom 3/5 kit
This is what i started at 2/3-4 kit on 24s
then the 3/5 on 24s
Escalade 2007 EXT
Hi I have a 2007 Escalade EXT have service suspension system the pump starts and shuts down in 3 seconds I have checked leaks in pipes and checked with compressor out and direct supply it works continuously disconnected battery to reset no help can you help I am overseas no dealer to support thx
Discussion Starter · #4 ·
might be the relay. These autoride trucks that i get in now i just save the customers hundreds of dollars. All you do is wire resistor in rear and then get regular shocks. Truck still rides great and honestly the time your going to spend to fix it just bypass the rear.
· Premium Member
2008 Escalade Sport, 2018 Escalade Luxury & 2018 Camry Hybrid XLE
The hose is leaking. Try to level the truck and disconnect battery for 5 min and plug back if not there is a hose kit that is the attachment and splits to go to right shock and the left hose connects direct to shock.
2011 Escalade
Hey Norcal, any help on the rims posted above?? They are the platinum rims, only in a black chrome/gunmetal finish? Let me know, I'm ready to order!! I have been looking around and cannot find them anywhere? They look sooooo slick... would look incredible on my black SWB!!​
Escalade ESV
Hi. Looking for some advise. I have a 2012 Escalade ESV with 22's. I'm wondering if I have to use the same shocks and struts that come factory with vehicle, or if I can get away with a cheaper kind since the air ride system helps out anyways? The struts are almost 1000 and the shocks are almost 1000...the normal cost of shocks and struts are normally a couple hundred only.
If you looking to do wheels or suspension on your escalade just give me a holler. I've done it all and sell the replica wheels and thru testing when these trucks first hit the streets in late 2006 I narrowed it down to the best kits for the 07 - 14 lowering. On my own escalade started with 22s then 24s then 26s. I went from a 2/3 to now a 3/5 and full swaybars and control arm upgrades plus more. Feel free to text/call me 24/7 at 415 519 2432 or email [email protected] Current height which is my custom 3/5 kit
then the 3/5 on 24s
What tire size?
1 - 17 of 17 Posts
