2007 CTS-V, 2008 BMW M3
I'm having a race shop to a custom 3.5mm spacer for my 07 'V and in order to make them hubcentric he needs some dimensions. I was wondering if anyone else has done this and has the dimensions I'm looking for.
He needs the wheel stud diameter, back pad diameter and Hub diameter. He was also looking for the bolt pattern but what kinda CTS-V nut would I be if I didn't know it was 6 X 115?
It is 6 X 115 right?
Does anyone know the other dimensions?
Discussion Starter #2
Oh and if any of you are interested in a set for your rears, just pm and I will get them to make some extras.
The cost is $30 each.
Whats the point of a 3.5mm spacer? I can understand 1/2" or 3/4", but 3.5mm??
Well if you go over 4mm then it is recommended that you make some adjustment to the studs which apparently is a huge pain. As well I have already put wider wheels on the car so this is all I need for the look I'm going for.
