Team Dynamics 18x9 275/35/18 nt05s on all 4 corners
https://sphotos-b.xx.fbcdn.net/hphotos-snc6/188238_10100759201890185_15794457_n.jpg
WOW amazing!! does anyone know what I'll need to do this swap?I'll just leve these here since they're appropriate
http://i110.photobucket.com/albums/n96/rub3n_05/ctsv2-1.jpg
http://i110.photobucket.com/albums/n96/rub3n_05/ctsv5.jpg
http://i110.photobucket.com/albums/n96/rub3n_05/ctsv3-1.jpg
http://i110.photobucket.com/albums/n96/rub3n_05/ctsv4-1.jpg
http://i110.photobucket.com/albums/n96/rub3n_05/ctsv1-1.jpg
New hubs, rotors... possibly calipers. I believe alot comes from the C5, so search up 5 lug conversion here, and it should pull up what you're looking for.WOW amazing!! does anyone know what I'll need to do this swap?
Who did you have do your calipers Randy? I'm looking to get mine done^^^ Those calipers look nice! Just did mine, too, but they don't look as flashy as red ones.
I bought those Brakemotive drilled/slotted rotors and pads, and while I had it all apart and on jackstands, I bought the G2 caliper paint on eBay and did them myself. 8th Day Creations has the V decals. Cleaning off the calipers was the biggest PITA, but even that wasn't too bad.Who did you have do your calipers Randy? I'm looking to get mine done
deep or semi-concave?Forgestar 19x9 & 19x10
So the paint/finish on the TD wheels doesn't seem to last?Team Dynamics in Steel It Paint. My Hyper Silver track wheels were beat after 3 years. The darker color seems more modern IMHO.
I love the red CTS V with the gunmetal Forgestars. I'm thinking about buying some for mine (don't worry, I'm in AZ so I doubt we'll ever park next to each other).
Thanks for the reply. Do you have any rubbing in front? It looks like you're pretty low... do you have any idea how much lower than stock you are?Rubbing will be an issue if you don't deal with it. I'm sitting on KWs and had them at their lowest setting, both rears rubbed on the inside fender. Had to raise the rear. That being said I've got stiffer springs as per fuzzys recommendation that I will be installing tomorrow.
I should note that, even though I raised the rear, the springs are still soft enough that some bumps cause rub. And some spirited driving did cause one of my tires to grab a fender, pulled it a lil bit and sliced the tire all the way around. Luckily it didn't blow but it cost me a new tire. So new tire, stiffer springs and inside fender fix tomorrow. I'm hoping I can lower it back down a 1/4" or so in the rear.
Other than all that, effing love the wheels and having 10" in the back. I do notice the difference vs stock.
