2010 CTS Wagon
I have a 2010 CTS wagon. 3.6 AWD. With stock 18's. I have a chance to pick up some 20's for a pretty good deal through a friend. Unfortunately they are incorrect bolt pattern. What are the thoughts on adapters from the 5x114 to the 5x120? Also with the 20's having a 40mm offset and then adding an adapter, will the wheels stick out? I've tried to look into offsets but unfortunately couldn't come up with an answer.... appreciate any and all help.
2009 CTS4 Premium & 2021 Blazer 2LT
A 3/4" thick bolt-on adapter is going to reduce the offset by 19mm. Stock wheel is 18x8.5 with 48mm offset. A change of 27mm will put the tire close to the fender.
· Administrator
'05 CTS-V
There's absolutely nothing wrong with using spacers/adapters, unless they're cheap and/or installed incorrectly. However, as FunkZ pointed out, a +40mm wheel with a spacer adapter is going to push those wheels out an inch or more compared to where the stock wheels sit. It certainly could be done, but if you're looking for a quick, bolt-on install with no issues, then find another set of wheels.
