so...2002 sts f55, i think that's the number, anyway its the fancy one...
symtom, front wheels shake while applying brakes going downhill at freeway speeds.
so i took the tire off. pads are a little less that 1/2 inch. rotor surface ok. not the best but ok.
so this is what i discovered. i can actually move the rotors back and forth about an 1/8 of an inch...maybe more. it seems like the rotor hole is bigger that what it goes on. its not a snug/tight fit. so i put the tire back on and i grab the tire at 12 and 6 no movement but at 9 and 3 there's that back and forth movement again. feels like i need rotors that just fit snug/tight.
so what are your thoughts?
via past experience you guys know where to get parts....so where do i get rotors and/or bearings, also a camshaft position sensor, and valve cover gaskets. oh, and brake pads with the extra stuff/hardware/sensors
as always, thanks for the help
