04 Deville, 11 DTS Premium, 00 Deville (sold), 02 Deville (sold)
A front wheel bearing on my 02 Deville has developed quite a growl. I plan on replacing the Hub assembly with a Timken 513179 this weekend. It's difficult to tell if it's coming from the left or right and I don't really want to replace the wrong hub.
When I do quick "S" turns the growl goes away when I turn to the left... so I'm thinking the driver's side bearing is the culprit. Is my thinking correct?
Thanks, MC...
Took about an hour to replace the drivers side hub this morning the growl is gone.
I need to replace a wheel hub as well. Did you go with the Timken 513179?
Yes, Timken makes a quality hub for a decent price. It was about $90 delivered from Rockauto. If your going to keep the car don't cheap out with a Chinese hub unless you want to change it again. Go with Timken or AC Delco.
Make sure you use a torque wrench (118 ft lbs) on the 34mm axle nut. Torque is critical... over or under torque will cause premature failure. Both a 34mm socket and torque wrench are available for free at Advance or Autozone under the loan-a-tool program.
