Wheel Adapters 5x115 To 5x120
4.8K views 2 replies 3 participants last post by  TA Coupe
I had got these 19 inch rims awhile ago for 50 bucks. Found out recently they are 5x120 and my bolt pattern is 5x155. The reason I am considering the adapters, it would be cheaper then buying new rims as I cracked one of mine on a pothole and the beads on them are pretty worn out and eventually always seep with new mounted tires and need reseals more often then I like. I am curious has anyone had experience with wheel adapters? Here are the ones I am looking at 4 Wheel Adapters 5x115 To 5x120 1.25 Inches Thick 32mm 12x1.5 Studs Also known as 5x115 to 5x4.75 adapters . And heres the rims I bought for 50 bucks ALY4729U77 Cadillac XTS Wheel Hyper Silver #22926094 .
#3 ·
Just keep in mind that now your Wheel and Tire are going to stick out 1.25 in. further and you may rub depending on what the offset is between what you have and the new ones. If the new ones have more backspacing then you may not have a problem.
Roy
