1 - 20 of 36 Posts
I'm a Cadillac Fanatic!
Short trips or long idles?
Let's say I'm taking a trip to the pizzaria. It's only 5 minutes away. Bad, bad, bad... So what if I leave the car on and go in? Worse, worse, worse? Or is it better that I'm leaving the engine running a little longer - making for a longer trip?
I've heard many times that idling is the worst thing for your engine...
01 frontier , 89 Shelby CSX vnt
letting ti idle for anything over a minute is bad , i remeber in alaska a gas engien that idled for long periods of time would end up haveing a higher occurance of gas in the oil (small ammounts) but none the less makes the oil not last so long
2005 CTS-V, 1994 Infiniti Q45
I think short trips would be worse.... But that all depends on how long your talking about idling it....
I personally think its a good idea to let your car warm up for 5 mins before you drive it..... I heard once that you do as much wear on an engine on a cold morning startup as you do on a 50 mile cruise......! Starting and going puts a lot of stress on the engine and tranny...
However, hot idling isnt good at all....
My auto teacher told us that it's good to rev it up a little when you first fire up the engine because it's at max friction when you first start it up in the morning so if you rev it up the crank balancers will splash the oil on the cylinder walls for extra lubrication.
Banned
You should NEVER rev a cold engine at start-up, there is no oil in the cylender walls yet, and you are precipating wear! I read that 70% of engine wear occurs at start-up, so I wouldn't do it. When I was a kid, the old man that lived beside us was hard of hearing, and would rev the hell out of his brand new 1981 Impala. He thought if he did this it would warm up faster! Well his engine only lasted a couple of years and blamed Chevy for making crappy engines! You should have heard it, I have never heard a V8 scream like that and I hope I never will again.
I don't know where I heard it, but supposedly aluminum engines should be warmed up good before being driven. Does anyone know if that is true?
Hmm, thats not a bad trick.... Ill give it a try tomorrow morning.....
However, I think the engines do this for the most part already... When you start it up (using my car for an example) it goes to 1500 RPMs for a second, and then settles down at 1250......
Ralph........ I dont think he was talking about really revving it up... My take on it he was talking about like below 2000rpm (completely safe).....
I think you are right in saying aluminum engines need more time, because they expand and contract more.... But Sal has an iron block, so thats not such a big deal to him!
Unicycle
This is a really interesting story I found on the internet (well, someone found and posted it at the GAOC...)
Unusual mystery; why did this happen?
I have an 89 Pontiac 6000 STE with a 3.1 liter V6; it's an older car I
have owned for about, seven, or eight years. This car has about three
hundred, and fifty thousand miles on it. I use the car to drive to
where I work; as a mechanic at a Dodge dealership, because of its age
I don't have to worry about getting the seats dirty. When I bought
this car it had something like; forty thousand miles. I always
changed the oil on this car and flushed the radiator, since I got it.
Over the years, I have put 2 new radiators, a used transmission, 6 new
fuel injectors, and various sensors, and seals; the car doesn't leak,
and its never been burned up. A couple weeks ago, this car had a date
with the junkyard due to having a mutual low compression in all the
cylinders; between 70 to 90 except cylinder six. Cylinder six for
what ever reason, had over one hundred, this would cause the car to
vibrate while idling. I knew its days were numbered.
One day I went inside, left the engine running, forgot about
it, and went to bed. The next day I got ready for work when I
realized why I had no keys. I guess I'm lucky no one took it;
although I probably wouldn't have cared that much "Good Luck". When I
got in the car I noticed it was running perfectly flat, as I drove to
work I noticed a dramatic power increase, almost like someone replaced
the rings and valves while I was asleep. Now my lowest cylinder is
120. The only thing it could have been was sticky valves, but no
clicking was heard from the engine. Its been two weeks now, and I'm
shocked it runs like it did five year's ago, and all that happened to
it was I left it idle for eight hours. I know I'm getting rid of it,
and for a good reason, but my curiosity makes me want to take the
heads off it, and try to figure out why this happened.
I always thought I was really bad to leave a car idle at night
when you went to sleep, although the heater would always be warm. One
friend who is an engineer told me, leaving the engine idle for that
long, probably polished the cylinder walls off. This would make
since, because of mileage on the car, and the short trips; I'm sure it
could have used rings. I knew that was probably what was wrong with
it because it would run bad; until it got hot then it would run worse,
or so the rule goes.
Kind of strange; it should be dead. Did the apocalypse come while I
was asleep?
On the other hand cars warm up faster when they're actually being driven, so letting it sit and idle for a few minutes is probably about as bad as it is to start it and drive off. Usually I just wait until the engine starts coming down from the fast idle. On fuel injected cars that's usually pretty quick, on carbureted cars it's a bit longer. Depending on how cold it is outside I'll let the car warm up enough that it's starting to blow out a bit of heat but if I'm going to be driving for a while I usually don't.
This is what I've been told by a number of techs. Later model engines ( Meaning late '80s To present ) are supposed to be designed to be run with a realitivly breif warm up period The supposed rule of thumb is to start it and wait till it's running smoothly and you're off. ( This is a very short time ) I'm not a big fan of this line of thinking but I've been told that it's way OK. I know that the new Heavy duty diesel engines are not as prone to damage without a long warm up as they used to be so it stands to reason that smaller automotive engines would be more tolerant of breif warm ups as well. As far as the question of extended idle periods....That's never been a good idea in any engine ( With a very few exceptions ) The modern heavy diesels have a fast idle setting so that you can keep the engine running for extended periods of time without damage due to low oil pressure and such. Automobile engines don't have this feature that I've ever heard of so it stands to reason in this case that you're not supposed to run them without a load source for very long. ( Engines are designed to be under a load ) It has never been considered a good idea to idle your car for very long. I read with interest ( And skepticism ) The earlier post about the high milage engine that miraculously cured it's own low compression issue by leaving it running. I rather doubt that it's a true story. ( Lies? On the internet?..Impossible! LOL! )
For about 4 months now, I've been letting my car warm up to about 150 degrees+ before driving. Anything below 120 degrees and I experience a fast idle. Once the car is warm, it drives wonderfully. Driving from a cold start makes my car mad....what's worse is that you have to brake harder due to the fast idle.
I'm thoroughly against revving or driving from a cold start thinking that's the best way to warm the engine; you can just feel the cylinders struggling to get toasty and lubed. IMO, the gradual idle process is the best way to extend the life of your engine.
I agree with chuck that is acually what i do everymorning i start up my car and go back inside to pack my lunch and wait a while then go in ride is much better.
Banned
Interesting info. Plus, you supposedly get better fuel economy if it is warmed up a little. Interesting about the 3.1 Pontiac. We have a 2.8 Pontiac with a quarter million km's and I do notice a little less power. (compression loss?)
KC, if it's written in a book, it's gotta be true! :D :yawn:
That's funny Ralphie boy! It's bullsh*t....But it's funny!
Discussion Starter #16
I usually start my car with the gas floored to the bottom; then just throw it in drive.. The wheels spin so fast that the car somehow flies backwards down the driveway. Once in the street, it hooks-up and heads down the road with no problem.
I let my cars warm up for about 30 seconds and then just take off and drive very easy until I get heat... Then I slowly start giving it more gas as time goes on...
I had to let my car run for 10 min this morning before i left for work... no cus i wanted it to idle... there was no way in hell i was gunna drive in a car that was 12 degrese!
Unicycle
hmmm, I just get in my car (when it is cold like now) start it up, let it run for about 30sec while I get everything ready and stuff, then drive.... although I am easy on it.... and you should never race a cold engine.... my friend had a '98 Mazda 626, 5spd, he would pretty much floor it the second it turned over, let it redline, then dump the clutch.....did that all the time...he had the car for 5months, it was a great car when he got it, then on Thanksgiving, he blew a rod right through the block.....
I would like to hear more about that guy with the 6000 and if anyone could support it or something....
1 - 20 of 36 Posts
