2004 Cadillac CTS-V
I've been developing this noise for a while now and in the past it would go away after driving at highway speeds or with a couple miles. It's a high pitched noise that used to be a pattern like 1, 2, pause, 1, 2, pause etc. Now it's almost a more even squeak. It seems to be coming from the middle or the rear of the vehicle. It's speed related and has no correlation with gear, clutch engagement, or RPMs. The dumb thing is that the speed range is changing all the time. My brakes were changed just a few thousand miles ago and are not near the squealer tabs. I've been looking at carrier bearing threads but none have had a sound clip. I recorded this with my phone: http://youtu.be/GdGOP2UfuwQ Hopefully this helps for future references.
The warmer temperatures seem to make it happen more frequently although before I thought it only happened in the cold. Should I get the lithium grease ready or is this something else?
If it is a squeak that matches the speed of the car,it has to be something that is 1:1 ratio with the ground. I would look at wheel bearings or your DS carrier bearing or possibly something in your diff.
2004 Cadillac CTS-V
In my experience, all the bad wheel bearings I've heard howl instead of squeak intermittently but I could jack up the rear corners and move the wheel around to check. I'm the only one I know who can drive or that I trust to drive my car so I'd have to find a passenger to ride in back because it's hard to pinpoint where it's coming from; middle or corner/wheel area.
In my opinion, locating the source of squeaks, howls and grinds etc...is one of the most challenging things to do. I have a noise coming from my driver door that sounds like a bead bouncing around. It is intermittent and I have been "looking" for it for 3 years now and can not find it. Drives me crazy! :mad2: So I feel your pain.
2004 Cadillac CTS-V
3 years sure would be annoying.
