1 - 2 of 2 Posts
Okay, need some help from those of you with 26" wheels installed. I have a2006 EXT and I am installing a set of 26" TIS10's this week. The dealer is telling me to "expect" rubbing. They said they will do their best to minimize the rub with ties but it won't totally fix the problem. How much rubbing should I expect and is there any tricks beyond the ties I should consider?
N/A
Beyond the ties there really isn't anything else I'd consider. With 305/30-26s you will have rubbing up front when at full turning, though depending on the offset of the wheel it may be more in the front, or rear. The TISs should be around +15mm to +25mm to fit the most optimum for your year Escalade.
1 - 2 of 2 Posts
