1 - 20 of 25 Posts
7lbs, But a guy in tech support at Magnuson said they were capable of 10-12lbs as long as the blower wasn't spinning over 14-16k rpm's. I'm getting a custom blower cam made and adding the Volant CAI, some more BMR stuff and lowering the car, so was going to do everything at the same time, how much didi you pay for your 2.6?
Mike
G
it is capable of 12 lbs safely. i am also getting 7 lbs with the 2.75. 2.6 cost me 120 u.s. i also have a custom cam going in,with afr heads, meziere electric water pump, full aeromotive fuel system, msd coil packs,ls1 edit,eibach springs,oil cooler,exedy twin disc clutch/flywheel, and a tnt wet nitrous system. my heads shipped out today and that is the only part i am still waiting for. as soon as they arrive it goes into the shop.
2005 Stealth Gray CTS-V, 2009 Black CTS-V
So let me know if I'm not correct with this.
3.0 pulley = ~5.5 to 6 lbs of boost
2.8 pulley = ~7 lbs of boost
Any expectations for the 2.6 pulley? ~8 lbs of boost would seem logical, but...
wildwhl said:
Luna -
with headers and at 4,500' I see just over 6 psi with the 2.8" pulley. Before headers and with the 3.0" pulley I saw about 5 psi.
I find it interesting you mention the headers.
Are you suggesting that headers help with boost?
Luna -
Nope...headers do help make some power, but the boost drops with the headers - nearly 1 psi in my case. There are several articles available on line to explain why - basically free flowing equals less back pressure equals lower boost numbers ;)
Not sure I'd do headers again...but the HP thing just gets so addicting :bonkers:
I am getting 7.5 pounds of boost.. i am little past or just past the .5 bar on my guage, looks to be .6... last i checked the conv. that was around 7.5
1 bar is suppose to be 14 pounds of boost.
My dealer called me friday and said smaller pulley is otw.. i should have mine by a week. but be careful.. make sure your psitons dont get roasted.. i had all my pistons ceramic coated for SC's and nitrous, to keep them from spot welding lol.. cerimac coating will give you a better smoother & even burn across them without all those burn spots.
you should have seen my plugs before i changed them... SC is like a jet engine.. i had 5 cracked plat plugs,,, the ceramic around the plugs were burnt into, chunks missing.. when i get a chance i will get close up shots of them... plat plugs & SC is a fubar screw up.. trust me.
later blitzer
later blitzer
Exactly, get the NGK TR55's
1 - 20 of 25 Posts
