1 - 16 of 16 Posts
CTS V 2005
What is the best short shifter to get for my 05 v. I want to order one ASAP. I have heard UUC was the best but over priced. I saw that Lyndsay Cadillac in VA has them, and they are priced at 400 bucks. Are there any others out there that share the quality for less $$??
CTS V 2005
Can you tell me why you hated the UUC so much. From my research i heard they were the best. I am just trying to get further opinions before I purchase.
Im thinking i may order this Ralco shifter. Do i need new bushing when i order this?
G
It always had side to side slop, didn't reduce the throw enough, transmitted noise/vibration, after 6 months the bearings that they use instead of bushings were seized up and the knob height was increased. I finally got fed up one day and modified my stock one.
I've been on the V forums for 5 years and have never heard the UUC one called the best. If you search long enough there are threads on this forum that compare the top ones. There is even a spreadsheet with all the comparisons in one place. These comparisons are from people who have either had multiple brands in their vehicle or have tried others at different V get togethers.
'05 Raven/Ebony CTS-V with toys
UUC is not the best, imo. I didn't like the one that I had in my Audi A4 and no one else did either -- I too basically gave it away for another brand...even with their bearing kit, it was horrible.
I have a B&M in my V and its a vast improvement over stock, but good luck finding one as they don't make them anymore and old stock appears to be gone. I bought one of if not the last one that Atlantic Speed had on its shelf back in the Christmas time of 2010.
CTS V 2005
Discussion Starter · #12 ·
Thanks for the advice. Looks like I will be buying the Ralco. I see them here on ebay through that link above for $199.00.
PISNUOFF- Is there any difference between the RalcoRZ link above that jmargo posted and the one that you have for sale. Because I keep everything stock from my car in case I ever want it back.
07 CTS-V
The Hurst shifter for a GEN-V Camaro can be made to work. I'll probably go this route, don't know what I have in my car is it came with it, but it is very numb...to the point that it almost feels like a short throw cavalier shifter. Weird. I like the positive feel and the noise that comes with...just me.
Brian - how much for your bushing kit for the shifter linkage? IIRC you had custom bronze bushings made...is this true and are they still available?
04 V
I would make sure you contact them and verify they corrected the problems to their prototype before you lay down any money.
17 xt5 & Blk 05 cts-v
I have a uuc shifter in my wife's silver car. I have a modified stock one in my car. If pisnuoff would have been around when i changed them i would have bought his. I modified the stock one according to the faq at the time. If ( and i think it would be ) pisnuoff's shifter is like he says it is i would MOST definitely buy his. Hell im thinking of switching the uuc one out. Dont waste your money on the uuc or any that are copies of it.
G
The Ralco looks to be the same style as a UUC. Here is some research for you. The links below were going on when I first started modifying shifters. Do some more searching on this forum and you will find a ton more information on shifters. Since then I have modified over 150 shifters and have refined my design and method of reattachment. I also replace the stock bushings with redesigned, tighter fitting, longer lasting ones that reduce the slop significantly.
https://spreadsheets.google.com/pub?key=t9xuoNd-zlXso0XilzG22wQ&single=true&gid=0&output=html
http://www.cadillacforums.com/forum...t-another-shifter-comparison-thread-time.html
I have one set available right now. They are for the trans end of the center linkage bar and require removal of the trans to install. $50 for the set. I sell my replacement bushings for the base of the shifter for $75 a set.
1 - 16 of 16 Posts
