1 - 8 of 8 Posts
NONE
I have a feeling that I need one that supports CAN-BUS (or another similar acronym). Can anyone confirm what type of OBDII scanner(s) work with the 05+ STS?
'05 STS4
Your car is CAN-bus for sure and, if I can offer MY Personal suggestion for the very beat one to invest in, I'd say, look at the AutoEnginuity.
It does Much More than the, less expensive, ones do. You have to be sure you're comparing Apples-to-Apples when you look at them all. Some just read the basic codes, some read all systems (trans/body/abs/traction/ etc), some can be used to modify settings for diagnosis purposes (cylinder contribution etc). The AutoEnginuity does it ALL!
It's a HUGELY complex issue to find just what a particular tool will, and won't, do for you. For the long-run I think this is the one to get (not cheap though even though YOU'RE supplying the LapTop)
'05 STS4
I'm not sure it does them All.... But think it's as close to a Tech-II as you can come. Call 'em, they'll tell ya ;)
I bought the "Big-3" service so it does the Caddy, the wifes PT Cruiser, and my F350 diesel (it even "buzz-tests" the injectors on it)
I did a lot of research before I decided on it, and as I said Really alot to look into, but am confident I made the right choice :)
NONE
Thank you for the confirmation of CAN-bus, and the recommendation for a scanner that works. I'm a pretty technical fella, so, the more info/control is often the better to me... :)
D
Guest
Basic Question: on OBD readout !
Where is the OBD port on the 05 STS,V8 not -V Northstar ? :helpless:
Thanks :hmm::hmm:
1 - 8 of 8 Posts
