For reprogramming the remote control
you can NOT program a REMOTE -
you program the CAR to recognize the particular pattern of a particular REMOTE -
MATCHING the remotes with the car REQUIRES the use of the TECH2 scan tool -
you can MATCH 2 remotes to the car -
the FIRST remote MATCHED with the car becomes DRIVER1 -
the SECOND remote MATCHED with the car becomes DRIVER2 -
regardless of the number on the case of the fob -
you MUST have BOTH remotes present and MATCH both remotes during the same process -
as soon as you enter the the process - ALL previous remote codes are erased -
if someone could describe the procedure to me point by point
all you need to do is follow the prompts on the TECH2 screen -
pick the car - pick the task - YES - it is that simple -
