1 - 12 of 12 Posts
· Banned
1993 Triple Black Allante
Hello everyone.
I finally got the chrome seven spokes from the Sandman and I love them. Now I have my stock wheels which are the original arrowhead/bullet design wheels that were a $1200 option when the 1993 Allante was new stored in the garage. They need a good cleaning and brake dust removed from the back of the wheels.
Any suggestions on how to clean them up so they look like new?
I also want to keep the new to me seven spoke chrome wheels looking new so I'm open to suggestions there as well.
Thanks for any tips.
Don
I use Brakekleen to remove dirt and brake dust.....Then I wash with soap and water and apply a good coat of wax.....They come out great!
2005 CTS-V, 1994 Infiniti Q45
If its mainly just dust, a little windex seems to work good for me, that is, if their not too bad.
· ...Reloaded
'05 XLR
Check out my old post about Cape Cod Cloths. BTW, when Don says he finally got the wheels from me it doesn't mean I was slow to send them, it's just the way he chose to receive them :D . We want pictures!
I used Eagle 1 A2Z wheel cleanner on mine and they came out looking brand new. That stuff got brake dust off that was caked on from before i bought the car! I though the inside of the spokes were supposed to be brownish, then i took that stuff and a tooth brush to it and they look brand new!
· Banned
Discussion Starter · #6 ·
Thanks for the suggestions. I tried the brake cleaner on the back side of the rims, and it helped some. The brake crud is on thick and I think its going to take some more elbow grease to clean them right. My goal is to get the back as clean as the front. The wheels are aluminum, with crome on the front side.
Would SOS pads work better on the aluminum? Thought I ask before it start using them.
I did pick up some Eagle One A to Z for maintance for my wheels, but haven't tried it yet.
Would a pressure washer work for the back side? I do not have as much work to do on the front side. The Eagle One wight work well between the spokes/slots with a toothbrush as suggested.
Looks like I still have some work to do.
Thanks for any help.
Don
Ive seen it at autozone.....
Don, we kind of abandoned you!!
A pressure washer is fine for any parts that you dont see, like the back of the wheel. I would put some simple green, full strength, let it sit a few minutes, and blast away! I think that pressure will do, and SOS pads most likely will not be needed....
I dont think you will get them as clean as the front, since a lot of the hot brake dust material actually "bonds" to the metal,; that is, unless you sand it.
· Banned
Discussion Starter · #9 ·
Thanks Wes,
I used the AtoZ cleaner in combination with the brake cleaner on the back of the wheels. I got most of the dust off the backs. They look alot better, but as the buyer said " no one see the backs. The AtoZ works well on the fronts with a little effort one the non crome areas.
I got Eagle AtoZ at Autozone.
2012 Escalade, 2014 SRX
If you clean them good with car wash, or Simple Green if they are real dirty, and then clay them they should come out looking new, followed by your favorite polish/wax to protect them.
Good news: I picked up some Simple Green and AtoZ wheel cleaner. I was only able to do about 9 spokes on one wheel before the weather turned ugly. Anyway, I washed the wheel, sprayed SG, and made the mistake of using a brillo pad and metal brush to scrub the 10-yr old grime off of about 5 spokes. It left behind scratches, but fortunately, I had some Meguiar's Scratch-X remover which cured it right up. Then when the SG couldn't get the heavy stuff in the corners, I tried out the AtoZ. The stuff is a miracle. Now I have 9 like-new looking spokes and can't wait to do the rest of the car! Thanks for the recommendations.
:burn: :D :banghead2 :cheers: :banana: :cool: :wave:
For wheel cleaning i would recommend P21s wheel cleaner.
http://store.yahoo.com/classic-motoring/p2wheelclean.html
or you can try P21s' Total Wash (least i think thats what its called)
once they are clean, I would suggest 1 of 2 possible ways to keep the wheels looking clean, and making future maintenance much easier.
One is to use Klasse All In One (AIO) and Sealant Glaze (SG) on each wheel. The other option is to use Wheel wax.
1 - 12 of 12 Posts
