I got my 2000 dts about 3mounths ago. it has 90,000.00 miles on it and i just changed to oil, what services should i be gitting done as i hit 100,000.00 miles. the car is very beautiful and i wan't it to run that way...
1998 Deville D'Elegance
Definately get the coolant changed by a GM dearler or OTHERWISE VERY REPUTABLE shop. Doesn't need to be a caddy dealer. Think about getting the hoses changed. Check the brake pads and rotors. Check the exhaust system for any rust through or leaks. 4 wheel alignment and a good interior and exterior detail :thumbsup:
2010 DTS
Drain and change (NOT FLUSH) the trans fluid. Clean the TB. Clean the EGR. Check plugs and change them if needed. Flushing the brake lines is not a bad idea at 100K.
