'10 3.0 AWD Sedan
3.0 auto, only has 300 miles so far. When its warm the oil pressure goes to about 25 @ idle. That sounds low to me but its a modern engine so I don't have anything to compare it to. Comparing it to my '70 Cutlass with a big block V8 is apples to oranges. What are you guys seeing?
'09CTS 3.6DI RWD GoldMist/Cashmere
Same here. With a warmed up engine the range on my 3.6DI is between [email protected] and [email protected]
I assume, since those modern 'full synthetic' oils have a really low viscosity (almost like water), the lower oil pressure is normal.
In the 'old days' even a too high oil pressure could have caused to get your crank and rod bearings to get 'washed out'. Thereby, the bearing surfaces got damaged.
pinkguy
Really Cool '11 CTS-V Wagon
Switching from the standard CTS Wagon to the V-Wagon where the oil pressure gauge is located, the V has a gauge for the supercharger pressure. The vast majority of the time the charger is not engage and I look down think for a moment I don't have any oil pressure.
The V doesn't have a oil pressure gauge.
