This back headliner piece is toast and I need a replacement but I cant figure out exactly what it is called (or find part number) to search e-bay. This is a picture of Passenger side, I actually need driver side but may get both. Any help appreciated.
2004 CTS-V, Black, Borla exhaust
What do you mean by "toast"? Mine came loose and the fastener behind it was broken. I used some thick two part epoxy, and pressed in place overnight. Hasn't moved a bit...if that is your problem.
The mounting brackets on both are broken off and the passenger side piece is broken in half. Hoping some v's are finally showing up in the junk yards so I can find the pieces used.
Thanks again darkman
Any idea what the part number is for this? Is this part the same for base CTS and the V? 2005 V. Thanks
