My 2003 CTS is idling very rough and misfiring... I've looked around for any vacuum leaks and saw that this appears to be missing a tube possible. This is located along the firewall closer to the drivers side next to the power steering reservoir. Let me know if you can tell me if a tube/hose goes into this and where does the other end go to?
2002 Eldorado Biarritz
That is the IMRC/switchover valve. That nipple is supposed to be connected to a long vacuum line coming from the front of the engine that tees off to the coolant bypass solenoid, the IMT solenoid, and the vacuum reservoir. Hope that helps.
Thank you Tlorenzen but I had already picked up a new line for it. I appreciate your help and offer.
