1 - 20 of 20 Posts
A red 2007 escalade base and a orange 2004 lamborghini galla
Which of the escalades is the heaviest a 2008 escalade, a escalade esv or a escalade ext?
'16 VSport (wife's), '10 Escalade, '97 & '02 SS Camaro's, '15 Silverado LTZ
Looks to me the EXT is heavier than the ESV by 49 pounds.
http://www.automobile-catalog.com/model/cadillac/escalade_3gen.html
  • [*]Cadillac Escalade AWD, model year 2008, version for North America
    [*]5-door wagon body type
    [*]4x4 full-time (all-wheel drive permanent, electronic automatic system ""always-on""), automatic 6-speed gearbox
    [*]petrol (gasoline) engine with displacement: 6162 cm3 / 374.9 cui, advertised power: 300.5 kW / 403 hp / 409 PS ( SAE cert ), Torque net: 565 Nm / 417 lb-ft
    [*]characteristic dimensions: outside length: 5143 mm / 202.5 in, wheelbase: 2946 mm / 116 in
    [*]reference weights: base curb weight: 2581 kg / 5690 lbs, gross weight GVWR: 3311 kg / 7299 lbs
    [*]how fast is this car ? top speed: 230 km/h (143 mph) (theoretical);
    [*]accelerations: 0- 60 mph 6.6 s; 0- 100 km/h 6.9 s (a-c simulation); 1/4 mile drag time (402 m) 15.1 s (a-c simulation)
    [*]fuel consumption and mileage: 13/19 mpg (U.S.), 18.1/12.4 l/100km, 15.6/22.7 mpg (imp.), 5.5/8.1 km/l EPA ratings 12/18 mpg (U.S.), 19.6/13.1 l/100km, 14.4/21.6 mpg (imp.), 5.1/7.7 km/l EPA ratings average estimated by a-c: 19.8 l/100km / 14.2 mpg (imp.) / 11.8 mpg (U.S.) / 5 km/l
  • Cadillac Escalade ESV AWD, model year 2008, version for North America
  • 5-door wagon body typ
  • 4x4 full-time (all-wheel drive permanent, electronic automatic system ""always-on""), automatic 6-speed gearbox
  • petrol (gasoline) engine with displacement: 6162 cm3 / 374.9 cui, advertised power: 300.5 kW / 403 hp / 409 PS ( SAE cert ), Torque net: 565 Nm / 417 lb-ft
  • characteristic dimensions: outside length: 5660 mm / 222.9 in, wheelbase: 3302 mm / 130 in
  • reference weights: base curb weight: 2695 kg / 5941 lbs, gross weight GVWR: 3357 kg / 7401 lbs
  • how fast is this car ? top speed: 229 km/h (142 mph) (theoretical);
    • accelerations: 0- 60 mph 6.8 s; 0- 100 km/h 7.2 s (a-c simulation); 1/4 mile drag time (402 m) 15.3 s (a-c simulation)
    • fuel consumption and mileage: 13/19 mpg (U.S.), 18.1/12.4 l/100km, 15.6/22.7 mpg (imp.), 5.5/8.1 km/l EPA ratings 12/18 mpg (U.S.), 19.6/13.1 l/100km, 14.4/21.6 mpg (imp.), 5.1/7.7 km/l EPA ratings average estimated by a-c: 20 l/100km / 14.1 mpg (imp.) / 11.7 mpg (U.S.) / 5 km/l
  • Cadillac Escalade Ext AWD, model year 2008, version for North America
  • 4-door pick-up body type
  • 4WD (four-wheel drive, 4x4), automatic 6-speed gearbox
  • characteristic dimensions: outside length: 5638 mm / 222 in, wheelbase: 3302 mm / 130 in
  • reference weights: base curb weight: 2717 kg / 5990 lbs, gross weight GVWR: 3266 kg / 7200 lbs
  • how fast is this car ? top speed: 222 km/h (138 mph) (theoretical);
  • accelerations: 0- 60 mph 6.9 s; 0- 100 km/h 7.2 s (a-c simulation); 1/4 mile drag time (402 m) 15.3 s (a-c simulation)
  • fuel consumption and mileage: average estimated by a-c: 20.4 l/100km / 13.8 mpg (imp.) / 11.5 mpg (U.S.) / 4.9 km/l
Ok thank you for the help
2009 escalade hybrid
Where did they get the 143mph top speed? My 2009 escalade hybrid is limited to 100mph. My new 2015 escalade platinum is limited to 112mph. Are you saying the 2008's have 143mph speed limit? Who would have known.
Mine goes up to 160
The speed limiter is set to whatever the speed rating of the original set of tires was.
Discussion Starter #9
So even though the dash can mark 160 it cant go up that high??
Yep, it depends on where the speed governor is set per the OEM installed tire rating, its a marketing ploy.
2010 Platinum Escalade, 1996 Fleetwood Brougham
An Escalade is in no danger of reaching 160mph. (Not without extensive modifications) It could possible strapped to a chassis dyno that it might turn the back tires the theoretical 138 mph.
The automags rate the top speed of the new escalade at 130mph but after trying it here in a michigan race track it can only manage 112mph until you see the warning screen saying 112 mph speed limited.
The HPE1000 Escalade might have a chance. 2 1/2 - 3 tons is a lot of mass, not to mention high drag coefficient of the Escalade.
2007 STS-V, 2007 Escalade, 2003 Escalade EXT, 2014 ELR
I wonder if the EXT is a 1500 or 2500 chassis frame. I think the 2500 frame is quite a bit heavier than the 1500 frame.
08 Escalade ESV awd, 05 Yukon Xl Denali awd, 06 SRX sold
The ext is on a 1500 frame, that 2500 frame is going to make a bit bigger difference than 50lbs
Yeah, I was thinking between a heavier frame and less sheet metal since it's a truck bed that it might work out to that 50 lbs overall difference.
The Avalanche is available in a 2500 series so I thought maybe the Cadillac might be as well.
All Escalade Premiums, '16 ESV, '13 ESV, '10 EXT
I wish they made an EXT on a 2500 frame! They made the 1st gen suburban available on a 2500 frame, not sure if they ever did with the avalanche.
yeah mostly every model year suburban or yukon xl had a 2500 model and the earlier avalanche had it also
1 - 20 of 20 Posts
