1 - 11 of 11 Posts
Awesome 2010 DTS Premium(former CTS '10 owner)
Fuel info on DIC...don't understand
'10 DTS Premium, 13,179 miles
Hi -hope i don't confuse you all:
2010 DTS Performance on DIC (at least i know what 'that' is) when scrolling for settings/choices, there is one that says 'fuel' and shows 99%....
DH would appreciate anyone who could tell him what 'that' means and/or what he should do about it.
I looked in our book and could find nothing - (assuming i was looking in the correct area).
Many thanks in advance - Showgirl ..:helpless:
Thanks for keeping us updated Showgirl. I would also say that the reading you are referring to would be the Oil Life Monitor. The only fuel usage display that the vehicle has shows the usage in either liters or gallons not in a percentage. I hope that information helps you.
Jeff Morris, Cadillac Customer Service
Discussion Starter · #7 ·
Hello Jeff and all the kind people who replied -- i saw the readout myself today and was going to write in.
I found the 'item' in the Caddy Use Book and yes that's exactly what it was - it is the 'fuel-useage' setting... at the current time since it was never 'set' by DH, when he scrolled thru items it was showing ''fuel used'' 99% (or something like that)...the book did describe how to set it up if you want to have that show... unfortunately sometimes it's difficult to find things in the use/care booklet for the car ...takes some hunting/pecking.
Again many thanks to you all !!! :) Showgirl
Discussion Starter · #9 ·
So what folks, there is a way to change the fuel used to percentage? I don't recall that in the manual.
From my Manual, 2010 DTS, Pg. 4-63(scroll down to last item) -''showgirl'':
Trip/Fuel Display Menu Items
3 (Trip/Fuel): The following display menu items
can be displayed by pressing the trip/fuel button:
TRIP A or TRIP B
These displays show the current distance traveled since
the last reset for each trip odometer in either
kilometers (km) or miles (mi). Both odometers can be
used at the same time. Each trip odometer can be reset
to zero separately by pressing and holding the
set/reset button for a few seconds while the desired trip
odometer is displayed.
FUEL RANGE
This display shows the approximate number of
remaining kilometers (km) or miles (mi) you can drive
without refilling the fuel tank. This estimate is based on
the current driving conditions and will change if the
driving conditions change. For example, if you are
driving in traffic and making frequent stops, the display
may read one number, but if you enter the freeway,
the number may change even though you still have the
same amount of fuel in the fuel tank. This is because
different driving conditions produce different fuel
economies. Generally, freeway driving produces better
fuel economy than city driving.
Once the range drops below an estimated 64 km
(40 miles) remaining, the display will show FUEL
RANGE LOW.
If your vehicle is low on fuel, the FUEL LEVEL LOW
message will be displayed. See “FUEL LEVEL
LOW” under DIC Warnings and Messages on page 4-67
for more information.
AVERAGE ECONOMY (AFE)
This display shows the approximate average liters per
100 kilometers (L/100 km) or miles per gallon (mpg).
This number is calculated based on the number
of L/100 km (mpg) recorded since the last time this
display was reset. To reset this display, press the
set/reset button. The display will return to zero.
INST (Instantaneous) ECONOMY (IFE)
This display shows the current fuel economy in either
liters per 100 kilometers (L/100 km) or miles per
gallon (mpg). This number reflects only the fuel economy
that the vehicle has right now and will change frequently
as driving conditions change. Unlike average economy,
this display cannot be reset.
FUEL USED
This display shows the number of liters (L) or
gallons (gal) of fuel used since the last reset of this
display. To reset this display, press the set/reset button.
4-63
1 - 11 of 11 Posts
