Re: what could this be a sign off? *weird start up*
Just remove the 4 black bolts holding the engine cover (the big silver plastic thing on top of the engine with "Northstar 32 Valve V8" written on it).
Underneath you will see this:
I put a red circle around the FPR and a yellow circle around the fuel pressure release valve.
It only takes 5 minutes and ANYBODY can do it:
1. Once the engine cover is removed disconnect the small vacuum line (just pull it out) from the FPR and look for signs of gas on the nipple. Should be BONE DRY. Any trace of gas is a tell-tale sign of a faulty FPR.
2. If you do find the FPR faulty then go to rockauto.com and select your year/make/model and browse to "fuel and air" find the FPR listed in there. Get the AcDelco one no other.
3. When you have the new FPR locate the fuel pressure release valve (see it circled with yellow) and unscrew the cap. It works just like a tire valve, press on the tip and the pressure is released. Be advised the fuel pressure is ~40PSI so have a rag to shield yourself and the engine until the pressure is dumped into the rad (about 2-3 seconds).
4. Now you are ready to remove the old FPR. Remove that clip and pull it out. Make sure all the rubber "O" rings are placed OK and then insert and lock the new FPR in place (a dab of oil on the "O" rings helps). Connect back the vacuum line and put the engine cover back.
Repair done.
P.S.
1) Any time you are opening the fuel line make sure the ignition is OFF.
2) Since yours is a 99, the fuel line is nylon, minor detail, all is the same.
