I'm at sea level and I see about 9psi.
Mark
Mark
I'm about at sea-level as well, but I'm not seeing that much...I'd say, 7-8 psi or so. Then again, I'm not 100% that's accurate, as the crummy gauge reads in increments of 3... :bigroll:I'm at sea level and I see about 9psi.
Mark
Is that just with the 2.55? I thought you were running the 8.5" inch crank as well. Reason I said 15-16 was off if he was just running the 2.55.Yeah im at 15-16.. Same with OKC. Our cars must be broken. :O They are factory freeks....
:yeah:Is that just with the 2.55? I thought you were running the 8.5" inch crank as well. Reason I said 15-16 was off if he was just running the 2.55.
I spoke to Hannah and she said he is running 10% on crank and 2.55 blower pulley.:yeah:
but with that it will cause to have fuel issues...!!?I spoke to Hannah and she said he is running 10% on crank and 2.55 blower pulley.
I remember a similar mod on FBodies and GTO's where you had to pull something in the fuel tank. Some kind of pump I thought. The stock one was the size of a pen and the new one was a size of a quarter. Is that what you found to be the restriction? The owner of the shop I went to bet me that was the cause of the fuel restriction.YES im running a 2.55 upper and a 10% lower. A little more boost than what okc is seeing.. OKC is seeing around 14 here at our altitude. It may be different where he lives.
Im running more boost than everyone so far... But i have fixed my fuel issues.. Not an easy thing to do.. I will post info about that later when i get alot of free time. It requires pulling out the fuel tank assembly....
To
