Hi,
I have a 98' catera with a leaking radiator, I wanted to know how hard it would be to change the radiator. is there a manual that can help me?
also I picked up this radiator new for $321 taxes included I'll post dealer and number later.
Cadillac Technician
none
Try this
Disconnect the battery negative cable.
Remove the upper radiator covers:
- Release the self-locking tabs.
- Remove the cover screws.
- Remove the covers.
Drain the engine coolant. Refer to Draining and Filling Cooling System .
Remove the intake air resonator chamber. Refer to Intake Air Resonator Replacement in Engine Controls.
Disconnect the electrical connectors at the following locations:
- The primary cooling fan
- The cooling fan control switches
Remove the radiator air bleed hose from the radiator.
Remove the transmission oil cooler pipe fittings and seals from the radiator.
Position the pipes away from the radiator.
Remove the coolant hose from the secondary auxiliary coolant pump.
Remove the secondary AIR cut-off valve bracket bolts from the fan housing.
Remove the condenser-to-radiator bracket bolts (1).
Remove the radiator inlet/outlet hoses from the radiator.
Disconnect the secondary auxiliary coolant pump connector.
Lift and rock the radiator and primary fan together in order to unseat the upper and lower retainers.
Remove the radiator and the primary fan together from the radiator support.
Remove the primary fan bolts, if necessary.
Remove the primary fan from the radiator.
Remove the cooling fan control switches, if necessary.
Installation Procedure
Install the cooling fan control switches, if removed.
Install the primary fan to the radiator, if removed:
- Engage the tab.
- Install the bolts.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Tighten
Tighten the bolts to 4 N·m (35 lb in).
Install the radiator and primary fan together to the radiator support:
- Engage the upper retainers in the radiator support brackets.
- Engage the tabs on the bottom of the radiator in the lower retainers.
Connect the secondary auxiliary coolant pump connector.
Install the radiator inlet/outlet hoses to the radiator.
Install the condenser-to-radiator bracket bolts (1) until fully seated and not stripped.
Install the secondary AIR cut-off valve bracket to the fan housing.
Install the bracket bolts.
Tighten
Install the coolant hose to the secondary auxiliary coolant pump.
Install the transmission oil cooler pipe fittings and seals to the radiator.
Tighten
Tighten the fittings to 25 N·m (18 lb ft).
Install the radiator air bleed hose to the radiator.
Connect the electrical connectors at the following locations:
Install the intake air resonator chamber. Refer to Intake Air Resonator Replacement in Engine Controls.
Fill the cooling system. Refer to Draining and Filling Cooling System .
Install the upper radiator covers:
- Position the covers.
- Insert the self-locking tabs.
- Install the cover screws.
Connect the battery negative cable and reprogram all applicable accessories.
