61 - 66 of 66 Posts
Discussion Starter #61
Hi I am going to try this replacement, You did a great job of explaining how to do it but I would like to know one thing.. When you are putting the new actuator in how do you position the mix door “d” shaft so that is is in the correct position?
Set the temp to 90° and install the door wide open, or set the temp 60° and install it in the closed position.
Discussion Starter #64
Well I gave it a shot, it was a real bear getting back in the center control arm pin is hard to get into place but I finally got it back in and did a restart by removing the battery terminal shorting it out and. It still has warmer air coming from the drivers side vents.. Back to ground zero..
Any ideas other than changing the drivers side actuator?
Discussion Starter #65
I just made up a chart with the temperature set verses the drivers and passengers vent outputs. very interesting in that the stay about the same till &4 degrees then the drivers side starts to climb any ideas??
Chart attached
61 - 66 of 66 Posts
