1 - 20 of 31 Posts
Premium Member
Discussion Starter · #4 ·
Thanks.. How about computers and things like the suspension? Anyone have any experiences? Post 'em all here...
Hopefully this can become a thread that'll help me put together a list of things to "be aware of" or to put money away for "just in case"...
Thanks...
new central computer thingy (size of a golf ball) $500
They wanted $225 to replace the actuator that releases the parking/emergency brake
speaking of brakes...all 4: $800
trunk latch motor: $55
Factory stereo head unit: $900
Starter: $400
BTW these are for the parts only incl. my prior post
For my 92 Seville, they want 350 for they front and 400 for the back to replace my struts/shocks, can't remember. Anyway, they are computer controlled, but even cadillac uses a third party kinda thing that doesn't dependon the computer, so replacing them are cheaper than 2 years ago.
I've never had any computer problems. The computers in these cars are realitivly bullet proof!
Actuator to realease parking brake.....$ 50 at wrecking yard.
Brakes ......$150 all four including turn the rotors. Did the labor myself.
Stereo head unit Reconditioned ( Link on this site )..... $150 to $200. Installed myself.
Starter rebuild..... $50 did the work myself, including R/R.
KYB passive struts.....around $70 each! Installed myself!
You can maintain these cars inexpensively....But you gotta do the labor yourself! You should also shop around for the parts!many times used is as good as new. Many times you can buy the components and rebuild stuff yourself and save a ton of money!
These prices quoted are within the last month or two and are for my car and a couple of my buddies cars that I work on and represent my cost for doing the jobs myself.The brake job was on my car and the cost shown is the total that I paid + about two hours of my time!
1994 STS - pearl white
Stabilizer bar end links are a snap. I've done them on a few different vehicles. Quite often, you can even do the front ones without jacking up the car - just crank the steering to expose the link. Easier with the car raised, of course.
The only potential problem is rust (depends on your climate). The end links generally see a lot of tire splash & can rust in pretty good. Usually, if you can't unscrew the nuts, you can twist them off. The blue wrench (cutting torch) helps, but isn't essential.
I agree with that! The thing to remember is that it's just a bunch of stuff bolted together a certain way! As long as you can get it together the same way.....You're in business! These things are easier than you would think to work on once you get passed the intimidation factor I.M.O.!
Sal Collaziano said:
The shocks aren't $1000.00 any more? Wasn't there something to do with a computer chip attached that needed to be replaced when the shock was replaced.
You've gotta go back and read that post a little more carefully Sal. Passive struts! Not those silly Cadillac Computer Controlled nightmares!:D
53 Eldo, 54 CDV, 74 FWB 96 FWB (sold),1998 STS(sold), 03 ESV
Anything to do with ABS = $
2005 CTS-V, 1994 Infiniti Q45
There are going to be quirks like that on every car. No car is completely quirk free its entire life!!
Banned
Actually Wes, my dad's minty 1979 Nova has been absolutely trouble free. Also his 1978 Chev Bonanza truck, I have never seen another one of those. Come to think of it, wasn't it 1981 that GM started using computers for engine management? HMMMMMMM, wonder if there is a connection there??!
1999 Eldorado ETC coupe.
New brakes, new Vogue tires and 2 new mufflers on my ETC at 123,000 miles......$2,500. I shopped, it was the best deal I found.
At 125,000 miles new water pump and cross over gaskets. $775. Still a good deal.
This is an immaculate, garaged, fair weather 15 year old ride.
If it was a 15 year old Ford, Dodge, Lincoln or Jaguar, I'd hesitate doing even an oil change. I'd probably throw it over a cliff.
1 - 20 of 31 Posts
