According to the guage showen above my engine is running at 210 during normal street and freeway driving conditions, if traffic is heavy it runs between 210 and the first tick mark after 12 o'clock and will go back down to 210 right away after trafiic lets up. I have never seen it get all the way up to, or past the first tick past 12 after owning the car for about a month, I am a little concerned about this although I've read that these motors run hotter then others... What do you all think?
Perfect temperatures for a Northstar in traffic.
These engines DO NOT "run hotter than others". The thermostat begins opening at 188 and is fully open at 206..... using an 18 psi pressure cap the coolant will not boil until over 265 degrees.
.....remember that our fans go to SLOW at 224 and FAST at 236 because they are controlled by coolant temperature
with no A/C or DEFROST function set. If the fans come on, the coolant goes down to 213 and fans turn off, and the cycle starts again BUT if you run the HVAC in AUTO or DEFROST modes then fans run in SLOW all the time and the gauge should hang around 198-212 all the time.
Some of these cars don't ever run the fans at 45 mph+ highway - you don't need them then.
