1 - 11 of 11 Posts
Ok so usually these codes come up when i run them in my car for my service engine light.
P1035
P0141
P0147
P0155
AND
P1139
They usually read all of them but i check again and now the P1139 is just showing up. This means
Ho2S "o2 bank1 sensor1 insuffiecient switching.
Why did it used to read all of them and now is just reading this code? what does insufficient switching mean? help me out guys?!
2005 CTS-V, 1994 Infiniti Q45
Well all those other codes were probably history codes, and you cleared the codes and they went away.... Usually the history codes have to do with stuff like "engine near miss detected" or something along those lines.....
Insufficient switchings means the o2 sensor needs to be replaced..... The o2 sensor during cruise or mild acceleration directly controls the injector open time (when at operating temp).... Anyway, the computer controls the injector open time when the o2 sensors arent doing a good job.....
I dare say you will see some performance and gas mileage increase...... Also, i would replace ALL 02 sensors....
Oh..... Sorry, I didnt remember that you did that!!!! I have a lot of things to keep track of.....
Anyway, I guess I would check the harness connections..... Without a FSM, im not sure what to say..... I bet its electrical.....
Did you by any chance get the "universal" O2 sensors? If so, how did you splice them in? A poor connection could cause that code and inaccurate info to be fed into the computer.
I didnt put any universal o2 in. Didnt have to splice anything they all fit in there 2 before the cat and 2 after if im not mistaken. I just dont know what else to do! :crying2:
Are the manifold sensors the same? If so, I would swap them and see if the code follows. If it does, take the sensor back. If it doesn't, it is almost definitely a wiring fault. Check the connector and the wires for heat damage.
Discussion Starter #8
All my sensors are bosch. How do i swap the manifolds?
Not the manifolds, the O2 sensors. Before you do, check and see if they have the same connector.
Re: weird O2 sensors problem
The "front" O2 sensors (accessible from engine compartment) are unheated and have a different connector than the heated "rear" sensors (one before and one after the cat). They are not interchangeable.
It sounds like either bad wiring somewhere in the circuit or a bad O2 sensor. Yes, I realize they are new and it's frustrating, but you've got limited options at this point. Try switching the sensors before and after the catalytic and see if the code changes. If it does, you'll know it's a bad sensor. If not, it's probably bad wiring between the harness and computer but will require further diagnosis.
Discussion Starter #11
Well i am taking it to the shop tomorrow and see what happens. I heard its probably a dirty fuel injector? oh well wish me luck and wish my pockets the same! i'll let you guys know
1 - 11 of 11 Posts
