I hear you. It's crazy how many current codes there are, but no hvac actuator door codes. If there's no air coming out of the vents, would that be a vacuum leak or maybe a module??
I even found a small vacuum line that was broken earlier today. The previous owners really drove it into the ground. I'll get her all figured out
no vacuum anywhere in the hvac system -
your Seville is all electronic -
here is the problem - as I see it -
when the system fails -
the MODE should go to the DEFAULT vent setting -
which is defrost and floor - yours doesn't do this -
could be this - could be that - could be the other thing -
with the TECH2 tool - it's a simple procedure to force/test ALL the actuators -
and pinpoint the problem -
without it - you are stuck guessing/replacing parts -
with that said - climate control modules are really cheap on ebay -
here is one for $15 including shipping -
http://www.ebay.com/itm/00-04-CADIL...001|Model:Seville&hash=item51b8fbde78&vxp=mtr
true - it is worn - and doesn't look pretty -
at this point - you just need to get it working -
and it can save a lot of time testing -
