1 - 19 of 19 Posts
2K ELDO, 2K TURBO BUG, 69 VETTE ZZ4 2014 CTS, 2021 CT5 3.0
Well, I just replaced the a/c relay , erased all the codes and expected all to be well , But no ! Now the a/only blows cold on the passenger side not the drivers side ? Could there a blend door stuck or vacuum leak. I don't really know where to start on this one . Thanks for any help or ideas on this one . Hope its not to ugly
· Master of the Dark Art of Diagnostics
like always - start by checking for codes -
if no AC related codes -
check the AC pressures -
post BOTH the high side and low side pressures -
Discussion Starter · #4 ·
Tx ill check on this tommrow. Air is not "hot" more abient. No codes because I recently cleared them when I replaced the relay.
Finally got back to this Sunday AM. And I have a few more facts, Outside temp about 70 degrees . Passenger side vents are reading 50/52 degrees. and drivers side vents reading 80/82 degrees. No codes are showing up and I have a high side pressure of 175 /200. I cant do a low side pressure because my brother drove over the low side , when he used it last , TX Bro. Any additional ideas would be appreciated TX.
high side pressure seems about right for 70's ambient -
duct temp - when set to 60* - medium speed -
should be 42 or lower -
your driver side temp is above ambient -
passenger side is below ambient -
the Eldo still uses a mix of vacuum and electrical controls -
can't remember which controls what - between temp and mode -
I suspect a vacuum leak -
but am surprised there are no codes -
could be a mix door sticking -
try exercising the temp up to 90*
and down to 60* several times -
Discussion Starter · #9 ·
Thanks , for the diagrams Ranger , I was looking for something like this in the FSM but couldn't find it .After" exercising "the system like Basscatt recommended , I noticed that in the air conditioning mode the drivers vents are not blowing as hard as the passengers , in the heat mode they appear to be equal . Momentarily I thought that It was working but then it went back to not working . Is there anyway to physical check and move the blend doors by hand to check for movement . Also is it possible for a screw or something to fall down a vent get in there and mess things up . I've had the dash pad off so who knows . TX again for all the help.
· Super Moderator
2010 DTS
Make sure there are no vacuum leaks.
Probably. look under the IP on the drivers side. Not sure how accessible things are down there.
Not likely.
don't confuse the TERMS within the climate control system -
MODE DOORS controls WHERE the air blows from -
regardless of temperature -
MIX DOORS control TEMPERATURE -
regardless of the MODE -
the Eldo never got the upgrades/improvements to the CC system-
that the Deville and Seville got -
no manual MODE control - and still vacuum operated -
it is quite possible you have vacuum leaks messing stuff up -
Discussion Starter · #13 ·
Finally got back to this over the weekend . I checked the incoming vacuum and found it to be around 16 Hg . I checked the colored vacuum hoses with a vacuum gauge and found them all to hold vacuum' I still need to see if a actuator is stuck . So where do I go next ? Vacuum solenoid or the programmer. I still have no codes showing. High side pressure is still around 200. Is it possible to have correct high pressure and be short on R134a ?
high and low pressures work together -
and are BOTH relative to ambient temp -
high pressure alone is almost useless -
likewise - low pressure alone isn't much help -
Looks like I will need to buy a new set of gauges! Ill keep working on this as time permits. Tx.
Mountain 8205 - $56 - with free shipping -
http://www.amazon.com/Mountain-8205-R-134a-Manifold-Couplers/dp/B000JFHNG0
very high quality set -
nice 6' long hoses -
quick connect couplers for both high and low sides -
found a set on ebay for $46 - with shipping -
http://www.ebay.com/itm/Mountain-MT...349?pt=LH_DefaultDomain_0&hash=item462c561f5d
Discussion Starter · #17 ·
Just got back to this , I noticed when the fan is on with Air conditioner off it still blows warm on driver and outside air on passenger. so I'm pretty much convinced it is a stuck door or vacuum motor problem . No codes are present . I cant figure out how the short side panels are removed from front of the shift console. the ones by the gas pedal and the passengers left foot . They seem to move around but I can't get them to come off . I don't want to break anything . Didn't see anything on the FSM on this . I figure if I can see what's going on down there I might be able to figure this out .TX Eldo GUY
· Super Moderator
2010 DTS
Disclaimer:
The Eldo is different than my DTS console, but mine is pried loose from the rear, then work your way forward. The front has a 90 degree angle tab that is slid in to hold it. Pry the front and you break that tab.
Mine was broken when I got it and I had to JB Weld it. Once all the retainers are popped, you slide the panel rearward.
Check this link on Ebay. It has a picture of the backside. Look closely at the front and you can see the tab I'm talking about.
http://www.ebay.com/itm/Cadillac-SE...ver-/281713405917?hash=item41976d6fdd&vxp=mtr
Discussion Starter · #19 ·
TX. again ranger ill try and explore this option tonight . Hope fully with the help of the forum and me poking around I'll figure this out . I will update when I find out something new .
1 - 19 of 19 Posts
