CTS
i was cleaning car and i touched down where the seatbelt clicks in at. and it felt damp so i just pulled up the back seat and it was all wet and now iam just trying to figure out were it came from ???????
86 Bronco, 74 Ford LTD,1999 Deville, 1977 Coupe Deville
Re: Water Leak Not sure wear its coming in at?????????????
On one of the tv shows the guy rented a smoke generator machine like bands use. He put it in the car & watched for where the smoke came out.
'05 CTS-V
I believe clogged sunroof drains can result in water back there. Haven't experienced that myself, but search for threads about that.
2003 CTS
I've had this exact problem before. It turned out the drain holes at the bottom of one of the rear doors was clogged. You can clear them by running a slot screwdriver between the door and the seal and then up through the drain holes.
