94 Fleetwood, 83 DeVille
I'm looking for a 1983 Deville 4100 ECM.
I just bought back my first car from I was 16. Strange how I had just said I regretted getting rid of it, and then I found it FS on Craigslist. Anyways. I bought it and it refuses to start. It cranks, and will just about fire if you hold the pedal to the floor. I forget what codes it is throwing ,but they were Baro sensor problem, and ECM not getting power. Something like that, I will have to check again.
I will be checking the timing on it. loosen it up, turn the distributor to see if it will fire up. I know some how it was a few teeth off, so the wire placement was off. Not sure if that effected it.
I don't know what years used the same ECM. I know that the RWD Fleetwood was still using the 4100 until around 87. SO far I have not come across one in the LKQ's.
Good to know they used it for less years than I thought. But I can't say the Olds 307 was that much of an improvement.
1979 Sedan deVille d'Elegance
HT 4100 was in RWD deVille from 1982 through 1984 and RWD Fleetwood Brougham from 1982 through 1985. Good luck. :)
1983 FWB (Mac), 1981 SDV (Junkyard Dog)
Up until a year or so ago, you could still get reman ECM's from your friendly AC Delco dealer. I got one for my 83 FWB. Give them a try. Another jobber which might help would be NAPA.
Cheers......R.
