1 - 20 of 42 Posts
2005 CTS-V
Hoping you all can help me out. I have an '05 V with just about 90,000 miles on it and it's about time for a clutch. I've been doing some checking and want to get a monster clutch to swap out the original. Problem is, the shops that I go to want to only use the clutches they sell... and monster isn't one of them. Anyone have any suggestions on where I can get an aftermarket clutch installed at a decent price (note: I live in the city of Cincinnati). I'm willing to travel.
Thanks!
2004 Maggied CTS-V
Not that it will help with your install issue, but I have a brand new in box monster stage 2 clutch, 28# flywheel, remote bleeder, and arp hardware for sale. Got it, ended up needing to get my rear end fixed more than a clutch
2012 CTS-V Sedan, 2011 CTS Coupe, 2010 Ford Raptor
2017 ATS-V Sedan, 6-spd Manual
You may want to contact Heavy.
05 maggied CTS-V, 2017 NSX Whoo Hoo!
I have a brand new clutch from Katech just waiting to replace the Monster (which I have grown to really dislike).
Since I have started driving Mr. Vette, I am in less of a hurry to exchange it out.
(enjoying Mr. Vette).
04' Blown CTS-V 554rwhp 497rwtq
Heavy go ahead and just sell me that LS9 POS. You don't wanna mess with it....I got $600. :)
OP Stick with stage II or below if you want to stay with Monster. Stage III + is asking for hell.
2005 CTS-V
Discussion Starter · #9 ·
I'm not looking to do anything crazy with my V - won't be doing forced induction or anything that serious. If I do anything, I'll probably throw some cams in or something. Don't get me wrong, I like boost, but not for this car.
Yes, I would recommend the Level II as well. I've had it in for nearly 2 years and its great. I have heard that the Level III is pretty sticky and has a lot of chatter. I would not go to the Level III unless you are over 575rwhp and do a lot of drag racing. If so, that clutch will hold you just fine. But it will suck on the street from the reviews i've read.
Reactions: lollygagger8
Yep you and a couple others are why I don't tell people to completely stay away from Monster. The level II sounds like it does great but the level III is a nightmare!
BTW You wife drives one freaking badass truck! lol
LS6 CTS-V
I had a level II in mine but the only thing I would suggest if you're running the LS6 is to either run with the 28# flywheel vs. the 18# flywheel OR find out if Monster will sell you a disc that's NOT dual friction (although you'll lose some holding power). I was "tolerant" of mine but with city driving the dual friction disc would heat up due to having to slip the clutch for smooth take offs and after a little while would start to squeal pretty bad. I'd have to jump on it pretty hard a couple times to "fix" it. It seems that those with LS2's don't seem to have the issue quite as much - the only thing I can figure is that it may have something to do with the 6.0 having a bit more torque at lower rpms to get these pigs moving. So as far as I'm concerned: ls2 = 18#; ls6 28# - this is my theory.
2005 CTS-V
Discussion Starter · #14 ·
Just a quick update... I've contacted a couple of distributors that are near me - with the only one contacting me back being 90 miles away (I guess the place about 15 minutes away from me didn't want my business - the place in Kentucky e-mailed me about 20 minutes after I sent them an e-mail at about 11:30 p.m.).
I found a place that is trying to be the big distributor and installer here in town and they called Monster to be a distributor of their products - and also to get one for me. According to the installer, the company told him that I would need to get a C6 Premium Chromoly package to put in. This makes no sense to me whatsoever, but wanted to double check with some folks on here to see if this is correct. Like I said, I'm not trying to put big power in here.
Does this sound right?
Thats true. I think the only thing the "premium" package has that you need is the slave though. I could be wrong so double check but I do recall ordering the most expensive package they had (what he is saying you need).
If I were you and knowing what I know now about drive ability with these clutches.....I would go with a twin disc. There is a reason that a lot of the Monster guys are buying or looking at the LS9 setup. Myself included but this time I'm waiting for a year + from everyone before I jump on the bandwagon. Good luck with whatever you decide but if ANY chatter or drive ability issues are unacceptable I would look elsewhere....
Had I known what the Monster was gonna be, I would have went the LS9 in the first place, not withstanding any $ difference.
The dental work you require after shaking lose a couple of fillings more then makes up for that. :histeric:
I have an LS9 clutch sitting on the floor, my V in storage and I just don't feel like crawling underneath it this month.
But I will be DOGGONE IT. :bonkers:
Yes, you need the C6 Premium to fit the V. The lesser prices versions are for F body's and GTO's.
I dont think you need the 18lb flywheel though. The 28lb will work just fine...although I love my 18lb flywheel with level 2. :cool2:
I have an LS7 set up in my trunk, waiting to be installed. The Transmission guy I use seems to think this is the way to go. I hope this thing is smooth, I wouldn't want to shake loose my dentures.
:wisdom:
1 - 20 of 42 Posts
