1 - 2 of 2 Posts
1997 SEVILLE
If I spray starter fluid into air filter breather my Cadillac Seville will run but no spray no run, please help I do hear the fuel pump in the gas tank running.
2010 DTS
Re: Want stay running
:welcome:
First check your fuel pressure.
If that's OK (40-50 psi), then clean the TB.
If that doesn't help, then pull the IAC valve, clean it, and more importantly, the air passages.
If still no help, pull the DTC's. You may find one for a faulty IAC valve.
My money is on low fuel pressure (bad fuel pump).
1 - 2 of 2 Posts
