Does anyone know about vinyl repair on the dashboard? I bought the soap, the cleaner after using the soap and some sem vinyl paint for my dash. What happen was i used the scuff pad to scuff up the vinyl, then i washed it with water. Then I used the cleaner and scrubbed off the cleaner. After a coat of paint it started to bubble up all around the edges. So i cut some of the vinyl out with a razor and repeated the same steps. Once again it started to bubble on the corners. I did this 2 more times and it just gets worse and worse what should i do?!:banghead:
Should I cut out a sqaure section of my vinyl and just paint the whole square section?
