Option Codes | |
01S - TRIM COLOR SEAT MED TITANIUM | 1AR - TRIM COLOR DR PANEL MED TITANUIM |
1SC - PREMIUM COLLECTION | 1SZ - DISCOUNT OPTION PACKAGE |
4AV - INTERIOR TRIM JET BLACK/MED TITANIUM | 5A7 - SPARE WHEEL, NOT DESIRED |
6FD - COMPONENT FRT LH COMPUTER SEL SUSP (6FD) | 7FD - COMPONENT FRT RH COMPUTER SEL SUSP (7FD |
8FK - COMPONENT RR LH COMPUTER SEL SUSP (8FK) | 9FK - COMPONENT RR RH COMPUTER SEL SUSP (9FK) |
9H8 - AUX. DAYTIME RUNNING LAMPS | 9L3 - TIRE SEALANT & INFLATOR KIT IN PLACE OF SPARE TIRE |
A44 - MEMORY PACKAGE - DRIVER /FRT PASS. SEATS, OUTSIDE MIRRORS, TELESCOPIC STEERING COLUMN * POWER DUAL OUTSIDE MIRRORS ADJUSTABLE, W/AUTO DIMMING & TURN SIGNAL INDICATOR | A51 - FRONT BUCKET SEATS |
A69 - RESTRAINT SEAT BELT TENSIONER, FRT, VAR. 2 | A70 - RESTRAINT SEAT BELT TENSIONER, FRT |
A90 - LOCK CONTROL RR CMPT LID, REM CONT ELEC RELEASE | AE2 - LATCH RR COMPARTMENT, SAFETY, MANUAL RELEASE |
AEF - WINDOW POWER OPERATED, PASSENGER, EXPRESS UP/DOWN | AER - WINDOW POWER OPERATED, RR DRS EXPRESS UP/DOWN |
AFE - MED TITANIUM/JET BLACK ACCENT | AG1 - ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER |
AG2 - ADJUSTER PASS ST | AHR - RESTRAINT HEAD, FRT SEAT, UP/DOWN, FORE/AFT ADJUSTMENT |
AKK - WINDSHIELD STYLE ACOUSTIC PVB | AKX - WINDSHIELD TYPE SOLAR ABSORBING |
AL0 - AIRBAG SENSING SYSTEM, PASSENGER | AP9 - CONVENIENCE NET, TRUNK |
APG - PWR SEAT ADJUSTER, DRIVER, 4-WAY LUMBAR | APH - PWR SEAT ADJUST, FRONT PASS 4 WAY LUMBAR |
ATH - EZ KEY PASSIVE ENTRY SYSTEM | AXG - WINDOW POWER OPERATED-EXPRESS DRIVER UP/DOWN |
AXJ - VEHICLE TYPE - PASSENGER CAR | AYF - AIRBAGS, DRIVER & PASSENGER FRONTAL & SIDE IMPACT HEAD SIDE CURTAIN |
B34 - FLOOR �MATS, FRONT | B35 - FLOOR MATS, REAR |
B85 - BODY SIDE MOLDING, BODY COLOR | BTM - KEYLESS START |
BTT - PANIC ALARM BUTTON | BTV - ADAPTIVE REMOTE START |
C3U - ULTRAVIEW SUNROOF | C59 - VENT AIR, CONSOLE, RR |
CE1 - WINDSHIELD WIPERS, RAIN SENSING | CJ4 - CLIMATE CONTROL, TRI ZONE |
D70 - AXLE, 2.77 FINAL DRIVE RATIO | DA2 - ARMREST, REAR PASS THRU |
DBU - CONSOLE, FRT COMPARTMENT FLOOR, ARM REST SLIDING | DD8 - INSIDE REARVIEW MIRROR, AUTO DIMMING |
DH6 - MIRROR I/S FRT VAN LH & RH, SUNSHADE, ILLUM | DNV - MIRRORS, OUTSIDE HEATED, P0WER ADJUSTABLE, BODY COLOR, AUTO DIMMING, POWER FOLDING |
EA1 - POCKET FRONT SEAT BACK, LH | EA2 - POCKET FRONT SEAT BACK, RH |
EAL - SEAT TRIM, SOLEIL KEISEL MINI PERFORATED INSERTS, LEATHER SEATING SURFACES | EF7 - COUNTRY CODE, U.S.A. |
EPM - MODEL CONVERSION ALL WHEEL AWD | F38 - AUTOMATIC LEVEL CONTROL REAR AIR SUSPENSION |
F46 - ALL WHEEL DRIVE W/ ELSD * TRANSMISSION, 6-SPEED AUTOMATIC, AWD * DIFFERENTIAL, ELECTRONIC LIMITED SLIP | F55 - MAGNETIC RIDE CONTROL WITH REAR AIR SPRINGS |
FHO - VEHICLE FUEL GASOLINE E10 | FLA - TRIM DOOR PUR, SHEFFIELD, VAR 1 |
FX3 - STABILITRAK-STABILITY CONTROL SYSTEM W/ TRACTION CONTROL | G96 - DIFFERENTIAL, ELECTRONIC LIMITED SLIP |
GAN - RADIANT SILVER METALLIC | GNB - SUSPENSION FRONT PERFORMANCE |
GNE - SUSPENSION, REAR H ARM | HD7 - DOOR HANDLES, ILLUMINATED |
I16 - | IO6 - NAVIGATION SYSTEM |
J64 - BRAKES, ANTILOCK 4 WHEEL DISC BREMBO | J71 - BRAKE, PARKING |
K34 - CRUISE CONTROL | K4C - WIRELESS DEVICE CHARGING |
K4T - BATTERY, RUNDOWN PROTECTION, | KA1 - DRIVER & FRONT PASSENGER HEATED SEATS |
KA6 - SEATS, HEATED REAR OUTBOARD POSITIONS | KB7 - CONTROL MANUAL SHIFT, AUTOMATIC TRANSMISSION |
KD4 - RECEPTACLE ELECTRICAL, FRT CONSOLE | KEH - SHIFT LEVER, LEATHER-WRAPPED WITH WOOD |
KI6 - POWER OUTLET, 110 VOLT | KPA - RECEPTACLE ELECTRICAL, FRT CONSOLE RR |
KRV - REFRIGERANT LOW GWP | KTI - TIRE SEALANT & INFLATOR KIT IN PLACE OF SPARE TIRE |
KU1 - SEAT, VENTILATED DRIVER | KU3 - SEAT, VENTILATED PASSENGER |
KW7 - GENERATOR | LFX - ENGINE, 3.6L SIDI DOHC V6 VVT |
LHD - VEHICLE DRIVE LEFTHAND DRIVE | M7U - TRANSMISSION, 6-SPEED AUTOMATIC AWD |
MAH - MARKETING AREA NORTH AMERICA | MM1 - MERCHANDISED TRANS AUTO EQUIPMENT |
MWN - EXHAUST, DUAL-OUTLET STAINLESS STEEL | N38 - STEERING COLUMN, POWERTILT & TELESCOPIC |
NC7 - FEDERAL EMISSION OVERRIDE | NCG - LOCK ELECTRICAL CHILD LOCK SYSTEM (REAR DOOR LATCH) |
NE1 - 50-STATE EMISSIONS | NKC - NOISE CONTROL SYSTEM, ACTIVE NOISE CANCELLATION |
NR7 - STEERING WHEEL, LEATHER WRAP HEATED W/ TAP UP/DOWN CONTROL | NU5 - EMISSION SYSTEM CALIFORNIA |
NXC - POWER STEERING, VARIABLE EFFORT RACK AND PINION | OSH - PLANT CODE OSHAWA |
PCW - DRIER AWARENESS PACKAGE | PMA - SEAT ADJUSTER, DRIVER, THIGH ADJUST |
PMB - SEAT ADJUSTER, FRONT PASSENGER, THIGH ADJUST | R7E - ID-LICENSE PLATE BRACKET CHARGE |
R9N - CONTROL SALES ITEM NO. 89 | RAL - TIRES, ALL SEASON BLACKWALL |
RQA - WHEELS, 20" ALUMINUM, PREMUIM PAINTED (REPLACES STANDARD WHEELS) | SLM - STOCK ORDERS |
T4F - HEADLAMPS, HIGH INTENSITY DISCHARGE | T83 - HEADLAMPS CONTROL AUTOMATIC ON/OFF |
T95 - HEADLAMPS, ADAPTIVE FORWARD LIGHTING | TL1 - DELUXE GRILL |
TQ5 - HEADLAMPS, INTELLIBEAM | TS6 - LAMP STOP, HIGH LEVEL |
TSP - LIGHTING | TU2 - LAMP MARKER, SIDE |
U2M - SIRIUSXM AND HD RADIO + SERVICE SUBSCRIPTION SOLD SEPARATELY SEPARATELY BY SIRIUSXM AFTER 3 MONTHS | U80 - DISPLAY COMPASS |
UD5 - FRONT AND REAR PARKINGASSIST ULTRASONIC | UDT - INFOTAINMENT DISPLAY COLOR INFO DISPLAY (CID) 8", WVGA |
UDV - GAUGE CLUSTER WITH COLOR DRIVER INFORMATION CENTER | UE1 - ONSTAR(R) INCLUDES 5 YR BASIC PLAN PLUS 1 YR SERVICE W/ AUTOMATIC CRASH RESPONSE, NAVIGATION & MORE (SUBJECT TO TERMS SEE ONSTAR.COM) |
UEC - SENSOR, AUTOMATIC AIR CIRCULATION | UEU - FORWARD COLLISION ALERT |
UFG - REAR CROSS TRAFFIC ALERT | UFL - LANE DEPARTURE WARNING |
UFT - SIDE BLIND ZONE ALERT | UG1 - UNIVERSAL HOME REMOTE |
UH1 - INDICATOR SEAT BELT WARNING, RH | UJM - TIRE PRESSURE MONITOR SYSTEM (EXCL SPARE TIRE) |
UMN - SPEEDOMETER INST, MILES & KILO, MILES ODOMETER | UQS - AUDIO SYSTEM, BOSE SURROUND SOUND, 14 SPEAKERS |
US3 - ANTENNA DIVERSITY | USR - RECEPTACLE USB |
UTJ - CONTENT THEFT ALARM, THEFT DETERRENT SYSTEM | UV6 - HEAD-UP DISPLAY |
UVD - HEATED STEERING WHEEL | UVH - SURROUND VISION CAMERA |
V8D - VEHICLE STATEMENT US | VAV - FLOOR MATS, ALL WEATHER FRONT AND REAR (DEALER INSTALLED) |
VK3 - FRONT LICENSE PLATE BRACKET | VRG - VAA/COMPONENT REL COCKPIT |
VRH - VAA/COMPONENT REL STEERING COLUMN | VRK - VAA/COMPONENT REL ROOF TRIM |
VRL - VAA/COMPONENT REL FRONT HORIZONTAL SUSPENSION | VRM - VAA/COMPONENT REL FRONT VERTICAL SUSPENSION |
VRN - VAA/COMPONENT REL REAR SUSPENSION | VRR - VAA/COMPONENT REL TIRES & WHEELS |
VV4 - 4G LTE WI-FI(R) HOTSPOT WITH LIMITED DATA TRIAL AND MORE. (SUBJECT TO TERMS SEE ONSTAR.COM) | W1Y - CONTROL STEERING WHEEL, RADIO, REDUNDANT CONTROLS |
WGA - COLLECTION RDO EQUIP RECEIVING UNIT, RADIO | WMG - |
XFE - FUEL ECONOMY EXTRA FUEL ECONOMY | XL7 - FREQUENCIES RATING 315 MHZ, LONG DISTANCE |
YM8 - IDENTIFICATION LIMITED PERSONALIZATION OPTION (LPO) | |
